Wideband Sensor Placement
Old Jul 30, 2010 | 06:30 AM
twinturbogreg's Avatar
I have heard heat can shorten the life of a wideband sensor. With that said, would it be better to have the wideband sensor placed in the race pipe, or the downpipe?? I'm just about to order my turbo back exhaust, and I'm wondering where I should have the wideband bung placed. Thanks!
Old Jul 30, 2010 | 07:08 AM
1800bigk's Avatar
Either in the dp near the factory o2 or in the front of the cat will be fine.
Old Jul 30, 2010 | 07:25 AM
blk-majik's Avatar
look in the howto section. There are multiple threads with instructions
Old Jul 30, 2010 | 07:52 AM
I know how to install the wideband sensor itself, but what I'm looking for is experience from people that have had sensors in their downpipe vs farther down stream. I would like to know if it has made any difference in accuracy and longevity for the sensor and readout?
Old Jul 30, 2010 | 08:42 AM
Messidona's Avatar
AEM's instructions says 36 inches away from the turbo if i remember correctly
Old Jul 30, 2010 | 08:46 AM
Kracka's Avatar
I've always run mine in the testpipe.
Old Jul 30, 2010 | 02:35 PM
PERRIN_Chris's Avatar
Just make sure to follow the instructions with the kit you get. It should tell you at least X inches away from engine, or between X and X inches from engine.
Old Jul 30, 2010 | 02:41 PM
E6-X's Avatar
just before the factory 02 TP seems to work fine and a good location too.
Old Jul 31, 2010 | 06:01 PM
tephra's Avatar
just dont install it at 12oclock...
Old Jul 31, 2010 | 11:13 PM
aronjaskim's Avatar
What happens if you do?
Old Aug 1, 2010 | 02:39 AM
tephra's Avatar
heat rises, so the heat directly above the pipe is the hottest.
i killed 2 sensors that way, ever since I put it 90degs (3 or 9 o'clock) its been fine!
