Installing ARP Studs in 4B11..need help
Old Sep 4, 2010 | 10:40 AM
NOMIEZVR4's Avatar
I'm in the process of reassembling the motor. Its a built shortblock with a fresh head. We installed ARP studs, however as I'm sure some of you may be aware, the casting on cylinder head closest to the front cover is a little different. When removing the stock bolts, I was able to stick a socket into and through the head, however I cannot get a socket through the head to tighten the studs...is there a trick or a special tool that is used? Thanks
Old Sep 4, 2010 | 10:42 AM
NOMIEZVR4's Avatar
Pictures should explain the rest of the story..
Old Sep 4, 2010 | 10:52 AM
NOMIEZVR4's Avatar
pictures below..
Attached Thumbnails Installing ARP Studs in 4B11..need help-img_0354.jpg   Installing ARP Studs in 4B11..need help-img_0356.jpg   Installing ARP Studs in 4B11..need help-img_0355.jpg
Old Sep 4, 2010 | 12:05 PM
Bighec's Avatar
Have you tried a thin wall socket, or maybe a stubby socket. Can you fit it through the bigger end, and slide it over?
Old Sep 4, 2010 | 01:01 PM
Guru's Avatar
I used a crappy 13 mm 12 point socket and shaved it to fit in the spacing on the head. Nothing else would work for me.
Old Sep 7, 2010 | 04:25 PM
NOMIEZVR4's Avatar
^^ Technique works!
Old Oct 8, 2013 | 12:59 PM
CodeOfDaStreets's Avatar
I was curious on if there is a certain way to do the 1 by 1 method on changing stock studs to arp without lifting and removing the head, where would I find the best info on this?
Old Jan 21, 2015 | 10:17 AM
Gtizks's Avatar
good info! i should be doing this in about 28 days
EVO 4 life
Oct 26, 2015 08:11 PM
Kreeker
May 3, 2015 06:34 PM
turboDan
86
Oct 26, 2012 12:47 AM
Rob_GPT
Sep 25, 2008 11:12 AM
yikez
Apr 6, 2007 09:48 AM
