Rear o2 sensor plug... where the hell is it under the seat?
Old Sep 23, 2010 | 07:46 AM
derekste's Avatar
Originally Posted by ZWingerRyRy
What gas you running? E85 or Race gas are likely to kill o2 sensors quicker.
this is completely false.
the only fuel that will potentially wreck an O2 sensor is leaded race gas.
Old Sep 23, 2010 | 09:08 AM
mlomker's Avatar
I know from experience that burning oil will also do them in. I'm running open loop for now, for that reason.
Old Sep 23, 2010 | 09:50 AM
derekste's Avatar
I should have said "in an otherwise mechanically sound and properly tuned car" :P
hope the oil thing was nothing serious...
Old Oct 16, 2011 | 02:28 PM
mrblob20's Avatar
Where do you access the front 02 sensor??
Old Oct 16, 2011 | 02:59 PM
3dman1's Avatar
What codes are you getting?
Old Oct 16, 2011 | 07:13 PM
mrblob20's Avatar
I'm not, I want to replace my front O2 sensor (the one that controls fuel/air ratios). My car has about 160 000 kms.
So do you know how to access the plug for it? I followed the wire .. but it goes into the car somehow...
Old Oct 18, 2011 | 10:03 AM
black95tt's Avatar
I just had mine out so I'm pretty familiar with this. The FRONT O2 sensor runs up the top left corner of the passenger foot well , and then under the dash in the center console area. Basically you have to pull off the trim in the foot well on both sides (the left side requires removal of the entire center console), and pull the carpet up. Then you will see some styrofoam stuff, pull that back too. There you will see the grommet with the wire coming up through, follow the wire to where it goes underneath the dash, if you pull away a little but of the sound deadening cloth underneath the dash, you'll see where the connector is. It's fairly easy to get to. The rear o2 sensor connects underneath the passenger seat. Hope this helps.
Old Mar 8, 2015 | 06:07 PM
sshoty228's Avatar
hi guys i need help i received a a bank 1 sensor 2 code . The did research different websites have different info . Does a lancer 2009 gts have 2 or 3 sesors ?? and does anyone know the locations . I can see one right at the catalytic is that number 2?
Deceit
Site Feedback / Suggestions
242
May 4, 2004 04:39 PM
ferrarokid
23
Nov 25, 2003 10:43 AM
