Venting valve cover
Old Nov 3, 2010 | 08:46 AM
mlomker's Avatar
Venting valve cover
My car has issues with oil consumption and a local shop suggested that the engine isn't breathing well enough. I currently have dual catch cans with crank vents (check valves). The stock PCV is also in place (wasn't sure if it should be removed or not).
Has any other X owner needed to add additional fittings to their valve cover for venting?
I'm also considering trying one of the air/oil separator setups...GrimmSpeed and Beatrush have offerings.
Old Nov 3, 2010 | 08:55 AM
Kracka's Avatar
A local down here was having what sounds to be a very similar situation at our last dyno day; completing removing the catch-can setup and running only with the crank vent setup 100% eliminated the issue. I would try this as a first step. The problem with a lot of catch-can setups is their inability to flow high amounts of air.
Old Nov 3, 2010 | 08:56 AM
tsitalon1's Avatar
Here you go:
Just kidding...I would perform a leakdown, compression, and borescope test before drilling holes into my valve cover...
Old Nov 3, 2010 | 09:37 AM
mlomker's Avatar
Hmm. These are the Boomba cans. That would obviously be easy to try.
Old Nov 3, 2010 | 10:22 AM
aronjaskim's Avatar
Aftermarket Forged pistons increase oil consumption.
Old Nov 3, 2010 | 10:39 AM
binky's Avatar
In my Evo VIII - I deleted the PCV and use the -AN valve cover fittings from STM. I also am using a JMFab catch can with -6AN lines.
This setup has worked great on my VIII (I don't see any reason why it wouldn't work as well on the X).
-Bink
Old Nov 3, 2010 | 12:25 PM
mlomker's Avatar
I'm losing over 1qt when I go to an HPDE. That seems a bit much.
Old Nov 3, 2010 | 12:56 PM
aronjaskim's Avatar
1 quart after one event, yeah that's alot.
Old Nov 3, 2010 | 07:33 PM
ugakirk's Avatar
You aren't running royal purple are you?
Old Nov 4, 2010 | 07:10 AM
mlomker's Avatar
Amsoil but it was burning conventional during engine break-in as well. The motor happily spits dipsticks if you don't underfill the oil so clearly it's a tighter motor than stock.
So many parts were installed during that build that it might take a little time to troubleshoot.
Old Nov 5, 2010 | 05:52 AM
Kracka's Avatar
Originally Posted by SP33D FREAK
I dont see how a catch can could be bad.
1fast97gsx
16
Feb 2, 2015 01:11 AM
bigben
33
Nov 3, 2013 04:46 PM
Curt941
22
Sep 7, 2013 12:13 PM
tsidrift1
May 12, 2012 10:17 AM
crisdiarata
Aug 15, 2011 01:29 PM
