having hard time shifting
Old Nov 12, 2010 | 05:06 AM
EvoX-11's Avatar
She has about 260 miles. I am having very hard time to putting it in to 1st, 2nd and reverse.
When the car is cold it is even worse which is understandable but even if after driving around for a while I almost need to force it to shift into the first gear.
And the worst part is after taking off I cant sometimes shift to 2nd gear. Sit there and struggle in the traffic...
This is really annoying, I knew EVOs have crappy transmission but geez this bad?
What could be the problem?
Old Nov 12, 2010 | 05:58 AM
Kracka's Avatar
Take it back to the dealership and have them check it out. That sounds worse than usual and may just need some adjustment.
If they claim its "normal" then get some Redline tranny fluid, remove the clutch restrictor pill, get a full set of shifter bushings, and possibly a short-shifter too if you'd like. These things made a huge improvement on my car. I installed them all before even hitting 1,500 miles.
Old Nov 12, 2010 | 07:01 AM
EvoX-11's Avatar
Thanks for the suggestions. I am kinda scared that there is something serious going on...
Yeah I will take it today see if they can take a look at it.
BTW, where is clutch restrictor pill is located?
Old Nov 12, 2010 | 09:37 AM
evoxgsr2010's Avatar
To be completely honest, that sounds a lot like mine was. It wasn't just a minor thing. I felt it at all almost all times. After 22XXX miles, fluid change, and short shifter, it's a lot better, but can still be a pain occasionally. I would still definitely have it checked if you're concerned though. I kinda wish I had just to put my mind at ease early on, but it's probably all fine. I think some of them are just a little more finnicky than others. Hope yours is good to go!
Old Nov 12, 2010 | 11:58 AM
EvoX-11's Avatar
Yea I hope so too.
It is so annoying tho.
I went to get lunch 2hours ago when I came back I try to put it in reverse to back the car in same thing It took me good 1 minute to be able to put it in reverse...
Anyways, off to the dealer. See what they have to say.
Old Nov 12, 2010 | 04:38 PM
ugakirk's Avatar
When you can't put it in reverse, do you try to put it in third then fourth and then try revere again? That helps me everytime.
Old Nov 12, 2010 | 10:09 PM
EvoX-11's Avatar
Well evo tech called the mitsu tech line and been told that I need to continue with break and see if the problem still persists after.
I will give that a try and let you know.
Old Nov 15, 2010 | 02:05 PM
laxplayer14's Avatar
this happens occasionally for me as well. usually if its a slight incline, if u let it roll a little it should glide right in. sucks that we paid over 30k for a car that still has these issues
Old Nov 15, 2010 | 04:10 PM
supergengo's Avatar
Every once in a while, my reverse doesn't like to engage. If I engage a forward gear and let the clutch out until the friction point, I can then shift to reverse easily. Doesn't solve your problem for 1 thru 5 tho.
Perhaps double-clutching would help?
Old Nov 15, 2010 | 06:07 PM
EvoX-11's Avatar
Yeah, I know right. Well Mitsubishi's defense is bushings are too "stiff" and need to break in...
I might give that a try I guess...
Old Nov 15, 2010 | 06:16 PM
Optiblue's Avatar
Notchy tranny indeed! It might get better after breaking in! Miss the MR yet? :P
Old Nov 15, 2010 | 07:28 PM
EvoX-11's Avatar
Haha, not at all! Stick FTMFW!!!
Old Nov 16, 2010 | 06:47 AM
BoostedSlvrGSR's Avatar
I was already used to this from my Integra, it happens on a lot of trannys. Happened to me on my first day with my X, and I immediately put it in first, let the clutch out, and it went into reverse like a glove.
Dunno what it is that causes it.
0to140in9
10
Sep 21, 2015 06:30 AM
raywong
40
Sep 16, 2015 03:49 PM
AsILayDying720
Jan 5, 2013 01:39 AM
Chan
Oct 31, 2003 09:16 AM
IS2000
Oct 30, 2003 03:44 AM
