Transfer case factory overfill?
Old Dec 1, 2010 | 06:01 PM
FALCO's Avatar
After the 2nd visit the tech thinks that the fresh oil deposits (I reported) are still a result of the original "factory overfill". He checked both trans and T/C fluid levels, and both were correct. Since there is potential for collateral damage during a T/C replacement, I sure hope he is right. Dealer suggested I put more miles on the car and check again. I suspect (and understand) Mitshu wants to be real sure before they pay to remove/replace a T/C. By the way the dealer seems proactive and eager to solve this probem. Encouraging that others have had it happen without further issue. I'll post final outcome...Thanks. Has anyone had the T/C breather burp out fluid after high speed driving?
Old Dec 4, 2010 | 06:44 PM
GGIXMRSE06's Avatar
Could you take a picture if possible of the exact spot/section where you found fluid leakage?
Old Dec 21, 2010 | 07:17 PM
3dcalixpress's Avatar
im having the same exact problem 23k miles with boltons and just installed act hdss clutch .changed my driveline fluids around 21k and didnt see no signs and then needed a new clutch and now im getting the burp and smell after install.freaking me out and getting nervous.dont wanna spend on a new tc on a new car 2010 gsr x . it seems to smell when uphill and after moderate speed . im getting nervous..
Old Dec 21, 2010 | 07:26 PM
steven88's Avatar
if its happening after you got your clutch in, most likely it has to due with the clutch or installation
Old Dec 21, 2010 | 07:39 PM
i was thinking same thing .i didnt do it before.the shop said its just an avefill breather ,so kinda curious if is.im gonna schedule an appointment to have it looked at
Old Dec 23, 2010 | 10:28 PM
modthispny's Avatar
i've always had the leak and at times a very light smell of oil but when i got home tonight there was a real bad smell of oil and it was definitely smoking from the turbo manifold area..looked underneath and there was a lot of oil and i saw some oil dripping too.
i dont think we're dealing with overfills here..as mentioned by the OP...looks like the seal that holds the tranny and tc fluids is a problem in the 2010's...too many similar issues for it to be a overfill.
i work mon - fri and the dealer is closed on sat and also the following sat which is going to make it hard for me to take it in
Old Feb 15, 2011 | 08:18 PM
darkstang5887's Avatar
did anyone ever figure out this leak? my trans is leaking into the tcase and the seal is unavalible!! my tcase is just sitting on the floor for a week now!
EEVOH
10
Sep 23, 2014 01:43 PM
nor11384
Jul 3, 2014 02:59 PM
Kracka
130
Apr 5, 2013 01:27 PM
notenoughhp
11
Sep 3, 2011 03:31 PM
nutrulz
23
May 8, 2006 12:26 PM
