What large frame Turbo on a fully built 2.3 Stroker?
Ive used the GTX42R turbos and they spool similar to the GT series, slightly quicker. The billet wheel doesnt drop much mass from the rotating assembly, which means spool wont change much at all.
do you have boost graphs to suport your statement comparing the turbos you speak of? even then, tuning plays a big roll in the spooling of the turbo so without knowing FOR SURE that it is as best as it's going to get then how can we truly know.
HTA3582 or HTA3586
Mike @ AWD nailed it on the head. We have a special going on with turbo kits right now. check out our site.
http://www.extremeturbosystems.com - $900 off
Thanks!
Michael
Thanks!
Michael
Tuning does play a role in spool time, but when swapping from a GT turbo to a GTX with no tuning changes, you will see negligible differences. Even with some minor adjustments, you wont see the response of a GT3076R with the GTX35R.
wow, all the info on this board and people still advise the 6262 or bigger for fast spool
The 6262 does not spool faster than a standard Garrett GT35r, it's definitely laggier.
For fastest spool///
It goes in this order:
HTA 3582R - 59mm
Garrett 3582R - 61mm
HTA 3586R - 62mm
PTE 6262 - 62mm
PTE 6265 - 62mm
HTA 3794 - 67.5mm
PTE 6765 - 67mm
And so on....
Every turbo listed is capable of 650+awhp
HTA 3582R - 59mm
HTA 3586R - 62mm
PTE 6262 - 62mm
PTE 6265 - 62mm
HTA 3794 - 67.5mm
PTE 6765 - 67mm
And so on....
khalil1990
18
Oct 24, 2019 07:46 AM
ineedboostman
49
Mar 23, 2016 11:40 AM
demon39063
13
Sep 9, 2015 03:40 PM
