2010 ams fmic
Old Nov 26, 2010 | 08:14 PM
stageup's Avatar
2010 ams fmic
so on the 2010, with the revised brackets, you can't use the rubber grommet(off stock fmic) and have to take off that black metal L bracket that held on the stock fmic right? i mounted it directly to the chasis w/o any rubber, just the screw and 2 washers. (that were holding that L bracket on)
also did not see in the ams instructions to disconnect battery so i didn't.
anyone else install the 2010 yet?
Old Nov 27, 2010 | 12:08 PM
2010WWGSR's Avatar
correct i did the install on my 2010 i didnt use the rubber grommets either. Also had to take off the black bracket that holds on the stock fmic.
Old Nov 27, 2010 | 12:47 PM
pghdsm's Avatar
Yeah OP you did it properly. The 2008-09 model AMS FMIC used the rubber grommets but the 2010+ model does not. No clue why Mitsu changed the mounting styles between 2 years. NO battery disconnect required. Reuse your factory couplers and lube them inside with some wd-40 a little to allow easier installation.
Old Nov 27, 2010 | 12:55 PM
stageup's Avatar
sweet thanks, just double checking cuz it seemed odd when i couldn't find the "remove 4 bolts and the weight" part.
Old Nov 28, 2010 | 04:49 AM
twinturbogreg's Avatar
Can anyone post pics of this? 08 vs 10
Old Dec 1, 2010 | 11:18 AM
ETS Michael's Avatar
Interested to see pictures of this, we haven't had one complaint on the front mount intercooler install for the 2010+ and we use the OEM mounts on the bottom and the side.
Michael
Faust
76
Nov 6, 2018 06:47 PM
Piro Fyre
Aug 23, 2012 08:13 AM
Tubzzz14
Dec 22, 2011 11:02 AM
Renley
Evo X Dyno Results
27
Jun 15, 2011 03:11 PM
steven88
12
Sep 21, 2010 08:46 AM
