Help. Rear Diff leak
Old Dec 11, 2010 | 12:47 PM
tjac357's Avatar
My rear differential is leaking between the differential housing and the pinion housing. The Mitsu rep would have been ok with replacing the seal that is between the housing, but could not find one and refuses to buy me a new differential. Both the mechanics I've talked to said that if my diff did fail it wouldn't be at this part, since there is no torque applied to it.
I have the following questions:
1) Has anyone had this problem, if so how did you fix it?
2) If someone has had the diff apart and knows there is a seal there any information would be great.
3) Part number for the seal would be amazing.
Thanks guys.
The arrow is pointing to where the leak is.
Old Dec 11, 2010 | 03:33 PM
Gqracer's Avatar
I believe it is part # 5 where the leak is coming from.
It is probably leaking from the axle seal and dripping down to the differential. Might want to check that.
Old Dec 11, 2010 | 05:09 PM
tjac357's Avatar
it's not leaking from part #5. it's the in between the 2 housings. I may try and see if the seal #5 is the same as the unlisted one.
Old Dec 12, 2010 | 08:06 AM
Kracka's Avatar
Check the AYC hydraulic line fittings, it's very common for those to leak. Snug them down a bit, clean up the case, and see if that helps.
Old Dec 12, 2010 | 10:27 AM
tjac357's Avatar
thanks a ton. that's a lot cheaper than buying anything
Thoe99
378
Jul 30, 2018 05:56 PM
Kryptyk_
Jun 26, 2017 11:33 AM
deylag
Evo X How Tos / Installations
Sep 28, 2016 08:13 PM
tjac357
Jul 26, 2016 09:34 PM
insanechief
29
Feb 12, 2009 10:44 PM
