Where are you mounting your Alcohol Injection tanks & Pumps?
Old Jan 2, 2011, 08:29 PM
Freebs's Avatar
Just like the title says, I am just looking for pictures of where you guys are mounting the tanks for your alcohol injection kits. Also note which kit you are running with the pictures. I want to run alky injection on my X as I use it on every one of my boosted vehicles but I don't know how or where I want to mount the tank and pump.
An engine mounted tank would be the cats meow hahaha so to speak, even if it had to be a smaller bottle.
I am looking for a way to keep it tucked away as I regularly have a full trunk and as it is the trunk space is very limited as you know.
Old Jan 4, 2011, 02:04 PM
steinvb12's Avatar
I'd like to know too, but I haven't seen any engine mounted tanks. I like the one I ran in my Evo 8 and would be ideal.
Old Jan 4, 2011, 02:14 PM
UT_EvoX's Avatar
My Snow Performance setup is mounted in the engine bay:
You can see the tank and pump to the right, the controller is attached to the frame using about 12 in^2 of double-sided velcro.
Old Jan 4, 2011, 04:03 PM
Ron burgandy's Avatar
I have the Snow Performance kit also. This was the only good spot I could find. I made a bracket and bolted it in place.
Attached Thumbnails Where are you mounting your Alcohol Injection tanks & Pumps?-meth.jpg
Old Jan 4, 2011, 04:05 PM
Off topic, ut_evox, how did you get your picture that big? I can only get thumbnails to come up.
Old Jan 4, 2011, 04:08 PM
UT_EvoX's Avatar
You can copy the image URL and put it in IMG tags:
HTML Code:
[IMG]https://www.evolutionm.net/forums/attachments/evo-x-engine-turbo-drivetrain/163335d1294185619-where-you-mounting-your-alcohol-injection-tanks-pumps-meth.jpg[/IMG]
Old Jan 5, 2011, 04:14 AM
I see, thanks for the lesson.
Old Jan 5, 2011, 11:57 PM
Freebs's Avatar
Do you have any more pictures where you can see it better?
Also is this the tank you are using?
Old Jan 6, 2011, 09:29 AM
UT_EvoX's Avatar
That's definitely the tank I'm using. I just checked my photobucket and I don't have any photos of the methanol install, and my car is currently in pieces in my garage undergoing an engine rebuild, so I can't snap any of how I have mine installed until that's sorted. But basically, I have the pump mounted horizontally on the driver's side "frame rail" and the tank is hanging from a ghetto bracket that attaches to the headlight mounting tab.
94AWDcoupe
44
Nov 6, 2017 08:40 AM
ArchieBabes
May 20, 2008 08:24 PM
4WS Tuning
23
Nov 14, 2006 10:21 PM
DynoFlash
39
Apr 6, 2006 12:11 PM
Chris@nolimitmotors
21
Jan 24, 2006 10:03 AM
Quick Reply: Where are you mounting your Alcohol Injection tanks & Pumps?
