500 HP Evo X - Ignition Question...
Old Jan 27, 2011 | 04:49 AM
kryptonite8789's Avatar
Question 500 HP Evo X - Ignition Question...
I am about to get my X tuned and she should be putting down a little over 500 horsepower. My question is...what spark plugs should I put in. I've been hearing that the NGK Iridium +1 Colder ones work great. If so, what gap should I get them in? I am reading DSPORT right now and it is saying .032. Thanks for the help.
Old Jan 27, 2011 | 05:07 AM
Hiboost's Avatar
One step colder plugs can help control knock a bit when pushing the edge, but they could worsen MPG when your engine is cold although I never noticed anything. Using a .032" is far too wide of a gap, typically for a car around stock horsepower levels the .026-.028" may work ok, but when you start to flow more air past them I found that even that was too wide.
Right now at .022" I can run just about any boost and airflow levels through my engine that I can throw at it. When I was in the .028" range after switching to the GT30 turbo, I could barely run over 22 psi before encountering spark blow out.
Old Jan 27, 2011 | 05:17 AM
Ok, so you are running .022...sounds good. How much power are you pushing? Odd how DSPORT listed .032 then...
Old Jan 27, 2011 | 11:11 AM
murlo26's Avatar
I am running stock plugs at 570whp...they work perfect, I think mine are also gapped around .022".
I've seen way way more problems from people using other plugs that aren't stock then when people stay with stock plugs.
Honestly, i wouldn't stray from stock.
I believe there have been people up over 700whp on stock plugs and they work fine.
Old Jan 28, 2011 | 02:05 PM
Gump's Avatar
^ i'm with murlo....stick with the stock plugs...if yours are fowled head over to the stealership and grab a new set.
qwertymess
May 11, 2011 10:26 AM
KarbisX
38
Apr 13, 2011 06:31 PM
kamel500
Mar 28, 2011 09:16 PM
ChuckP
Sep 26, 2009 01:26 AM
EVOQUICK
Nov 14, 2008 05:35 PM
