what should be next?
current mods: intake, exhaust, downpipe, test pipe, and intercooler..
wish list: intercooler piping, cams, injectors, and tune...
problem: not enough money for all.
what should i get next to make the x a bit faster
helpp please!
helpp please!
So you have those bolt ons, with stock tune? I would suggest 2 things.... 1) Get a Hard UICP, there are cheaper ones out there, most do the same thing, to avoid flex with the stock rubber crap under boost. 2) get a tune, it is the best bang for the buck, whether it with a Cobb AP, or a custom tune. JUst a tune you'll be a happy camper till you get cash to go to next step. Also crush your stock DV, it is free and worth it... If your not sure how, search or have a tuner do it. Good luckk and happy Moddin.....
Well, since you didn't say how much you can spend, I would go with a UICP and a tune. You will be very happy with the results.
You will be shocked at how much more power you will make.
If you can't afford both I would just get a tune because that alone with make the car feel amazing and you can add the UICP later without a re-tune.
It is mostly a dress-up mod unless you are going for a new turbo.
Not sure if you guys checked out the Agency Power IC pipes[/url], but thought I'd throw out some info.
Cheers!
"Much like your rubber brake lines, intercooler hoses expand under boost pressure. This causes a drop in pressure and that results in a loss of power. To combat this, most people replace the factory intercooler pipe connectors with silicone hoses or a new complete hard pipe. Agency Power has taken the Mitsubishi EVO X intercooler piping one step further and has released the all new 1 piece upper intercooler pipe kit. The pipe connects from the top of the front mount intercooler end tank and is 1 piece all the way to the turbo pipe. The 1 piece aluminum pipe features a bracket to secure the intercooler pipe in the factory location. Utilizing mandrel bends, we designed the pipe to have a smooth air flow path without any restrictions. When installed, the intercooler pipe kit will fit securely with plenty of room for the factory engine cover. This kit is available with a diameter of 2.5 inches for improved air flow. (We also offer a 3" kit for high horsepower cars[/url]). By installing this pipe kit, you will maintain boost pressure more efficiently, pick up throttle response, and gain horsepower. As tested on a Mustang AWD Dyno with our short ram intake kit, this setup made almost 30 all wheel horsepower.
The pipe kit includes new silicone couplers and clamps for a secure and stylish look. The intercooler pipes are available in polished or gloss red, which also matches our short ram intakes and suction pipes. This part is a direct fit with no cutting or altering OEM components.
[/URL]
[/URL]
[/URL]
Cheers!
[/URL]
[/URL]
[/URL]
