acceleration jerking with bov
Old Mar 4, 2011, 04:45 PM
apagan01's Avatar
i had a forge with the same issue, i heard synaptic gets rid of these issues
Old Mar 5, 2011, 10:59 AM
kozmic27's Avatar
On the Synapse with the "old style" 3rd port on the side, run the 3rd port to boost reference on the turbo.
Old Mar 5, 2011, 11:16 AM
Robevo RS's Avatar
the BOV valve is not set it up right. I dont the type you have , but should be a screw on it. Try to loosen or stiffen it up all the way , and start form there.
Old Mar 5, 2011, 06:04 PM
evo x power's Avatar
Hey i just put a hard piping kit with bov and i have a wierd whine when boosting i pluged the one part but if i recirculate would this work better and eliminate the noise
Old Feb 13, 2018, 07:17 AM
Evoxtremegsr's Avatar
Having the same problem
I have a tial bov and having the same issue only in 5th gear when car builds a little boost then when it comes back to negative car sputters and jerks. Bov only has 100 miles.
Old May 11, 2018, 02:24 PM
EvoOtto's Avatar
I’ve had an issue similar to what others are complaining about. It would happen between boost and vacuum. I’m told it is a smoothing adjustment needed to help the ECU cope.
khaled_hourani
May 15, 2017 02:36 PM
Squatch
Mar 16, 2017 10:04 PM
High_PSI
119
Oct 4, 2016 08:20 AM
CokeEvo
Jun 29, 2016 11:06 PM
mrm95
Jun 2, 2016 07:21 AM
Quick Reply: acceleration jerking with bov
