Rods/Piston Combo's
Old Apr 1, 2011 | 12:03 AM
  #91
EVOhead's Avatar
Originally Posted by chetrickerman
you are right, and i was corrected, it happens
BUT, if his post is not wrong, then why does wiki say this:
but he says this:
just trying to get the right understanding/answers here as there are different ones here. Not insulting anyones intelligence
I understand you are not trying to insult anyone. Me neither by the way. I just want good info posted for everyone!
I read that statement on another site I found yesterday also and it's only for non-boosted engines.
The simple answer is on a NA car with 9:1 static comp. the overlap from the cams will take away some of the cylinder pressure thus lowering the dynamic comp. to lower then 9:1.
But with a boosted engine even with the lose of some pressure with overlap from the cams, turbo/supercharger engines keep cramming air/fuel into the engine keeping cylinder pressure higher then the static comp. There is only so much room in the combustion chamber
I just hope we helped to educate someone who read this thread
Old Apr 1, 2011 | 09:30 AM
  #92
chetrickerman's Avatar
Veteran: Army
well i got to learn some new stuff
Old Apr 27, 2011 | 02:54 AM
  #93
MDH-005's Avatar
It's a bit late for me now, but what are people's thoughts on Carrillo Rods?
Would be interested to hear!
Old Apr 27, 2011 | 05:46 AM
  #94
Robevo RS's Avatar
We got a decision on the new engine. So it will be a 2L with 9:5:1 compression.
Custom CP pistons and Manley rods.
Old May 6, 2011 | 03:16 AM
  #95
erniebu's Avatar
I'm getting ready to have my motor built and I've been reading up on rods and what they can handle, I always read 'its not the hp that kills its the tq' so that being said, what are the Manley H Beam rated for? I know hp they can go up to 600hp safely but I can't find anywhere what tq they can handle.
Thanks!
Old May 6, 2011 | 07:11 AM
  #96
murlo26's Avatar
Just get the I beams...don't skimp.
Old May 6, 2011 | 10:12 AM
  #97
erniebu's Avatar
yeah I know... but I was just wondering what the H beams were rated for as far as tq goes? I know the I beams are monsters.. what are those rated for?
Old May 6, 2011 | 10:37 AM
  #98
ETS Michael's Avatar
We run Cosworth rods and Cosworth pistons, never had one problem at 800whp and 9.X track times.
Rods
Pistons 9:1
The motor has been together for almost 2 years now, it may have low miles.. but they are definitely hard miles.
The block it self is stock w/ no sleeves and stock crank.
Good Luck!
Michael
Old May 7, 2011 | 02:43 AM
  #99
sailorcor's Avatar
Good choice, same here
Old May 7, 2011 | 11:37 AM
  #100
Robevo RS's Avatar
Rods
Pistons 9:1
Good Luck!
Michael
That was our other choice. But because the compression we did go for CP ( 9:5:1). And from there wasn't really a reason to go cosworth rods anymore. I also have a Manley H beam rods. Stock crank and block no sleeving. Stock head and gaskets. Colder plugs since we will run 104 race gas only. /rally rules won't let you run higher/
here is my set up :
Rob
Kevin_White19
Apr 10, 2017 01:36 PM
3gevoclipse
Nov 22, 2015 08:12 PM
RealStreet
Aug 24, 2012 10:31 AM
RealStreet
Aug 22, 2012 02:03 PM
DeliriouS
18
Mar 13, 2010 05:51 AM
