Best settings for oversteer under power (Attn track junkies)
Which setting on the evo are you guys getting the best power on oversteer results with? I am looking for a little bit more oversteer on the course.
Thanks!
Thanks!
Tarmac as it has been said to have more RWD bias.
Gravel is said to have more 50/50 with more bias towards traction control.
Snow is said to have more 50/50 with no traction control.
The settings are for how fast it will lock the acd on different positions.
Like tarmac is a loosest and the gravel is mid level the snow is almost instant lock between the front and the rear "axle". The evo has always a 50 - 50 power distribution between front and rear .
The ayc is only changes the power delivery on the same "axle" - rear only. The rest of the system plays with a brake to get more traction. The front is an LSD. And the same way works as a rear on additional traction, with a brakes. But the power delivery between a front and the rear as I said before is always 50-50.
That is why if you turn off everything the car will be faster in good hands. Since no brake system interfier in the driving. Fact if I leave it on I actually can get in trouble since I can't rotate the car with power. The SAWC system over rides it and try to make turns smoother, theoritically more controlled. And it does it with a abs system. So instead to rotate it will do a nice wider turn ergo go off from the driving line which I picked.
J!n K@z@mA
Feb 9, 2014 07:12 AM
el producto
18
Jul 1, 2005 08:44 AM
