Engine Coolant Temp value
Old Apr 22, 2011 | 04:16 PM
Noize's Avatar
EvoM Administrator
I have logged a few Xs in the past 3 weeks, and notice mine consistently reads about 15 degrees lower than every other one I've logged. Any idea why this could be? If I am moving and cruising, it stays around 174 degrees. Of course it raises up when I stop and idle as expected.
Any information you have regarding your own ECT or things I could check to troubleshoot a possible issue would be appreciated. 08 GSR with 18k miles.
Thanks
Old Apr 22, 2011 | 05:01 PM
RazorLab's Avatar
Remember we changed your ECT formula in Evoscan?
176 +/- is correct as that is your thermostat
Old Apr 22, 2011 | 05:50 PM
Noize's Avatar
EvoM Administrator
I do remember that, but still was getting a variation with the other guys the past few days as they were all around 190 or so on my laptop. If you are good with it, I'm good with it. Thanks!
Old Apr 26, 2011 | 09:01 PM
01CBR929's Avatar
Buy a BMW.... it won't have that problem.
Old Apr 26, 2011 | 09:06 PM
tephra's Avatar
mine however around 80C and lower...probably 74C -> 82C
Old Apr 27, 2011 | 06:31 AM
Hiboost's Avatar
Thermostats can vary a bit from car to car, and possibly some come with lower temp ones while some aftermarket thermostats crack open at higher temps based on their crack temp and fully open temps.
My own car hovers at 170-175*F where as my friend's MR was hovering at 160-165*F and was hard to tune and got sigificantly worse fuel mileage. Then I swapped in a thermostat from Stant and his car now hovers at 185*-190*F which is at least the temp you will hit anyways on the road courses when the cooling system starts to heat soak. Tuning at this temp was better in that now the coolant was closer to what the car would see on the track after 10+ minutes. MPG also went up a bit and the odd trickle knock at 160*F is no longer an issue.
With a new X-line Mishimoto radiator that is twice the thickness as stock, the return pipe on the radiator is literally cool to the touch so the thermostat is regulating lots of reserve cooling capacity in the system.
Old Apr 27, 2011 | 07:49 AM
blk-majik's Avatar
how's the timing setup? if the other cars are running more advance than you (relative to boost/load), you might see higher ECT after the thermostat opens up.
jheff
Jan 10, 2017 07:07 AM
Thoe99
Jun 6, 2011 10:16 PM
crcain
46
Mar 8, 2010 07:35 PM
Evo_Matt
Feb 8, 2010 09:57 AM
Porkskins
15
Jan 21, 2010 04:51 PM
