I need more stuff!
Old Apr 25, 2011 | 03:55 PM
Renley's Avatar
I need more stuff!
Ok, I just bought the following for my 2010 evo x gsr...
- AGP front mount intercooler
- AEM Cold Air Intake
- Agency Power Dual Catback Exhaust
What else do I need to get to make sure I am getting the most out of the above items before I head in for my tuner to tune the car?
- upper or lower intercooler pipe?
- downpipe?
- bigger fuel injectors?
- turbo timer?
- other?
i am trying to get the most out of the stock turbo i can at this time...
Thanks for the info guys!
Old Apr 25, 2011 | 04:00 PM
Pal215's Avatar
- downpipe?
- turbo timer?
- other?
Get everything you listed minus the turbo timer. Instead get a boost controller and a fuel pump to go with those fuel injectors. Also a high flow cat, intake mani, and exhaust mani couldn't hurt.
Old Apr 25, 2011 | 04:09 PM
Renley's Avatar
Do you have any recommended brands/items for each of those things you suggested?
Thanks!
Old Apr 25, 2011 | 10:40 PM
Pal215's Avatar
Thanks!
Yes of course. I believe that Buschur racing, ETS, and AMS are leading the way right now in terms of performance parts. For the fuel pump, most go with a walbro 255. As for the Intercooler piping, choose any of the three manufacturers i listed earlier. The milspec high flow cat is a 100 cell cat, making it one of the highest flowing cats available. As for fuel injectors, i dont have a brand for you, but i can tell you that 1000cc's are the size to buy, just in case you want to switch to e85 later. Search around the forums to find the best parts available and don't let anyone tell you to buy something just because they have it. Do some research, read through thorough reviews to find the best.
Old Apr 25, 2011 | 11:35 PM
evoxgsr2010's Avatar
On the stock turbo, unless you're going to run e85, you won't need bigger injectors or a fuel pump. Do the IC pipes (upper is more important on the X), a high flow cat or test pipe, o2 downpipe, and whatever kind of boost controller your tuner likes to run (mine STRONGLY prefers 3-ports over MBC's). Those things plus a tune should make you pretty happy
Old Apr 26, 2011 | 01:49 PM
Renley's Avatar
No, I wont be running e85, I just assumed that tuning the stock turbo to a higher psi would require bigger injectors.
So if I am to make a new list this is what i think people are saying:
- High Flow Cat
- AMS Upper Intercooler Pipe
- AMS Widemouth Downpipe
and maybe fuel injectors/fuelpump...
+Tuner suggested boost controller
anything else that would be truly worth the money on stock turbo?
Old Apr 26, 2011 | 03:55 PM
linjy2's Avatar
For stock turbo.
- Full turbo back.
- intake
- UICP only. LICP is useless upgrade since the stock one is so good already.
- oil catch cans
skip the injectors and pump on stock turbo.
get a boost controller if that is what your tuner suggest. but a 3 port is the way to go if he is willing to tune it for you.
Old Apr 27, 2011 | 06:12 AM
scheides's Avatar
EvoM Moderator
MAP o2 elim downpipe
megan testpipe
some sort of UICP (I like the nisei)
Stock LICP is fine but if you're doing the UICP and FMIC already....
Stock injectors are fine
stock fuel pump is mostly fine, but a walbro + install kit is great insurance IMHO.
last but very very most important--3-port bcs + a tune!
Old Apr 27, 2011 | 06:16 AM
scheides's Avatar
EvoM Moderator
Oh also, after all of the above, the best bang/buck on the stock turbo is to have it turned into a CBRD BBX or BBX Lite. Still stock turbo, right? :P
Old May 16, 2011 | 03:01 PM
Renley's Avatar
Well I am going to be doing autoX so I am not sure if even a FP red is needed.
My thoughts where that if i upgraded to a larger turbo, i would have to overhaul my suspension to keep my speed up, otherwise turbo lag would kill me....
Old May 19, 2011 | 05:32 PM
spiGini's Avatar
buy everyyyyyyythinggggg :P lol. id say just do a e85 tune and use that for autox instead of upgrading to red or anything else. fast spool plus nice power
Old May 25, 2011 | 03:07 PM
Stevo-9's Avatar
If you have the AGP intercooler get AGP's intercooler pipe. It matches the outlet size of the intercooler and relocates the BOV, cleans up the engine bay a bit.
Old May 25, 2011 | 03:12 PM
Stevo-9's Avatar
It's the cold pipe that matches the 3" intercooler outlet not the hot side, my bad
Old May 25, 2011 | 03:30 PM
ugakirk's Avatar
Intercooler piping, the rest of the exhaust parts (O2 downpipe, testpipe), grimspeed 3-port, and tune. You can prolly wait in injectors and fuel pump. The stock fuel system is actually pretty decent..
Don't get a turbo timer. Don't get a manual boost controller, get the grimspeed like I said.
Old May 27, 2011 | 07:31 AM
Synaptic3e's Avatar
no one mentioned a COBB AccessPORT?
i get set you up with one if you'd like and answer any questions
ca18hatch24
Nov 5, 2013 01:25 PM
GetterDragun
16
Apr 24, 2013 06:56 AM
boostincincy
Jun 26, 2009 07:49 PM
MR 600
44
May 22, 2007 10:37 AM
evobeatsti
70
Jan 7, 2007 05:27 PM
