Turbo area tapping noise
Old May 14, 2011 | 05:24 PM
sfearl1's Avatar
Angry Turbo area tapping noise
Alright guys, I've got a 2011 GSR with 18xx miles on it. Only mods are a defi boost gauge and a cosworth drop in panel filter. About 1k miles ago I started hearing this very distinctive tapping noise coming from what "appears" to be the turbo area/housing/rear of the engine bay. Totally freaked out by it bc, from what I can remember, it wasn't there when I brought the car home.
Can anybody tell me what this is? Hoping somebody has debunked this for just a backed out housing bolt or something else minor. I'm taking the car into mitsu Tuesday morning for an alignment and oil change and for them to take a look at this, but from everybodys take on the service there, I am not holding my breath on a quick fix.
Cold start and no tapping (not sure what that whirring sound is at the end, totally unable to hear that in person)...
http://www.youtube.com/watch?v=5fj6pUgd5fI
and hot engine with the tapping...
http://www.youtube.com/watch?v=L1xluF6Swpc
Old May 14, 2011 | 05:36 PM
brenner's Avatar
take it to the dealer
Old May 14, 2011 | 06:20 PM
Mike Bones's Avatar
Noisy stock injectors FTW!
Old May 14, 2011 | 06:23 PM
sfearl1's Avatar
Yeah, injectors are loud as hell, but they're easily distinguishable from the tapping sound.
Old May 14, 2011 | 08:13 PM
sfearl1's Avatar
Anybody have a clue what this could be?
Old May 15, 2011 | 03:42 PM
sfearl1's Avatar
bump, looking for more insight on this.
Old May 16, 2011 | 08:25 AM
ApexSilverXGSR's Avatar
I get the same noise at start-up. It goes away for me after a minute or two of warming up or just by driving very lightly until the engine is at proper operating temp.
Does your video represent a cold start-up?
If you take it in for inspection, let us know what you find.
Old May 16, 2011 | 11:41 AM
sfearl1's Avatar
No, mine only occurs when the engine is hot. The rattle/tap/clanging noise increases with rpms. Its metallic in sound like something is tapping the heat shield in sync with the fuel injectors cyclical firing.
Old May 16, 2011 | 12:49 PM
WarmMilk's Avatar
i had the same noise at the track after a couple of heats, but it goes away once the engine cools down to normal operating temp. I have no idea what it is... at first I thought it was the clutch/flywheel, but I have a Spec clutch and a ACT flywheel, I'm assuming yours is stock? If yours is stock, the clutch/flywheel idea kinda goes out the window...
I also have a 2011
Old May 16, 2011 | 01:01 PM
sfearl1's Avatar
I also have a 2011
about 99% stock. drop-in air filter and a boost gauge is all i've done so far. only 1850 miles on the car as of today.
Old May 16, 2011 | 05:40 PM
WarmMilk's Avatar
I have the Cosworth drop in as well... but I don't see how that could cause the knocking sound...
Old May 16, 2011 | 06:26 PM
sfearl1's Avatar
updated the first post with these too...
and hot engine with the "metallic" tapping noise...
Old May 16, 2011 | 06:36 PM
JDMCT9MR's Avatar
Have you taken off the heat shield and ran the motor to see if it may be easier to pin point the noise? Maybe a valve adjustment? Not likely since your car has such low mileage.
Old May 16, 2011 | 06:38 PM
sfearl1's Avatar
honestly i haven't touched the heat shield yet. i wanted to get some more input before i go taking apart the housing.
Old May 16, 2011 | 06:40 PM
JDMCT9MR's Avatar
The heat shield is super easy to remove. I think there are 5 or so 10MM bolts to remove. You may also have to remove the tower bar as well. This should give you a better view of the suspect area.
