Clutch pedal won't go down
Old Aug 20, 2011 | 11:47 PM
ImsoevoX's Avatar
The other night I was driving along shifting from 4th to 5th when my clutch pedal sank to the floor. I coast to a stop, get out and pulled the clutch pedal back up. The clutch wouldn't engage after that so I had to have the car towed. The clutch pedal is rock hard and won't go down. I was able to start the car but that was only after pushing in that little button on the clutch assembly and turning the key at the same time. I have an Exedy twin with the mangus upgrade. The clutch master is the oem one straight from fred beans parts. Any thoughts as to what this could be? The clutch has about 8k on it.
Old Aug 20, 2011 | 11:59 PM
Optiblue's Avatar
Clutch master cylinder failed again?
Old Aug 21, 2011 | 01:07 AM
Frankiago's Avatar
Any fluid leak that you can see? Behind the pedal or on the back of the engine under tray?
First thing that came to mind was whether or not the CMC says NABCO Japan on it, but if you got it from FBP then that's probably a yes.
If no fluid the only thing I can think of was improper clutch install but you would've had a problem well before 8k on it
Old Aug 21, 2011 | 05:38 AM
Kracka's Avatar
Check to see if your TOB broke or came unclipped from the pressure plate.
Old Aug 21, 2011 | 07:54 AM
ImsoevoX's Avatar
Yeah, a buddy of mine was saying it could be the throw out bearing. He also said it was a known issue with multi plate clutches on the 8's and 9's. The throw out bearing comes unclipped. STM makes a fork stop clip. So how would I check to see if it came out..and if that's the case is this something expensive to get fixed...
Old Aug 21, 2011 | 07:59 AM
ImsoevoX's Avatar
Just checked for fluid didn't see anything. I really hope that didn't fail, but just my luck if it did...fml
Old Aug 21, 2011 | 08:03 AM
Kracka's Avatar
Take a picture of your clutch fork sticking out of the bell housing and post it.
Old Aug 21, 2011 | 08:40 AM
Thegame's Avatar
There's also a small rubber plug that you can take out of the bottom of the tranny to get a glimpse of the pressure plate / TOB. If it did get unclipped, you can snap it back in with a long screwdriver.
Old Feb 5, 2019 | 01:20 PM
Leosjul000's Avatar
My clutch won’t go down
my clutch is doing the same thing I got home and was going to reverse when my clutch stayed on the floor I pulled it back up and now it won’t go down and I can’t start my car I also saw there where dry spots by the master cylinder I don’t know if something is leaking any help?
red_evox_87
Mitsubishi TC-SST Discussion
Jun 13, 2016 09:00 AM
CaptainSquirts
10
Jul 15, 2015 11:51 AM
Svendiesel
24
Jul 30, 2013 09:23 AM
TIGERJC
Apr 1, 2010 06:41 PM
trinydex
Mar 29, 2007 05:40 PM
