Concerned about the plastic valve cover.
Old Sep 2, 2011 | 11:26 PM
Vostok 7's Avatar
I'm planning on getting a stock replacement tubular exhaust manifold and I'm concerned about the plastic valve cover on the 2010. At some point I want to get an aluminum one, but if I were to use some high-temp engine paint and some of that gold heat tape, would it limit the danger of the plastic valve cover melting/catching on fire?
- Patrick
Old Sep 2, 2011 | 11:49 PM
HAHAV8's Avatar
I've seen plenty of people running the plastic engine cover, with a tubular mani.
I plan on doing it, ceramic coated with no tape or paints... It won't melt or start on fire.
Old Sep 3, 2011 | 06:53 AM
Kracka's Avatar
Use either heat wrap or good ceramic coating. A local melted his with a tubular manifold and a low quality ceramic coating. Paint won't do anything.
Old Sep 3, 2011 | 01:09 PM
Hiboost's Avatar
Tubular manifolds will melt it if tracked, while stock setups with stock heat sheilds should be fine on the street for obvious reasons. It's when you get the parts glowing hot and the heat sheilds are not there that stuff starts to melt.
Old Sep 3, 2011 | 01:12 PM
migs647's Avatar
Could always look at buying an aluminum cover. I've seen them for sale here and there.
Old Sep 3, 2011 | 01:13 PM
Vostok 7's Avatar
That's what I want to do but I'm not having any luck.
Old Sep 3, 2011 | 01:44 PM
Kracka's Avatar
Buy a new one.
Old Sep 3, 2011 | 02:16 PM
migs647's Avatar
+1.
Normally I wouldn't agree, because OEM is usually nutso in price. But is actually really competitive in pricing. PM Russell at mitsubishiparts.net, he usually sells for a good amount under retail.
Old Sep 3, 2011 | 03:29 PM
notenoughhp's Avatar
uh oh...
Old Sep 3, 2011 | 04:59 PM
HAHAV8's Avatar
So the consensus is if properly ceramic coated, the engine cover will be fine?
I was planning on this anyways, along with my DP, and turbo hotside.
Old Sep 3, 2011 | 06:07 PM
Kracka's Avatar
Yes, if it's a quality ceramic. Just watch it periodically and make sure it's not getting melty looking. You can also cut the hood scoop open a bit further to allow in more airflow.
Old Sep 3, 2011 | 11:18 PM
HAHAV8's Avatar
Good info. Thanks.
Old Sep 5, 2011 | 07:46 AM
VSGTS14's Avatar
swaintech coating. send it out. which manifold do you plan on going with?
macPSU
Apr 2, 2017 10:14 AM
blkdrgn09
Jun 15, 2015 09:19 AM
Gordian79
22
Jan 31, 2012 04:37 PM
wild01ride
Jul 2, 2011 02:13 PM
AJsGenerX
Apr 18, 2010 12:11 PM
