T-Case WHY!??
Old Sep 21, 2011 | 01:32 AM
AWD96's Avatar
What kind of clutch did you have put in? Are you sure the metal noise isn't clutch chatter in 4th and 5th gear at low rpm's? Check the wheel bearings too for the humming. If it's an Exedy Twin you might hear a few funky noises coming from it when you drive. I could be totally wrong but it's worth a shot
Old Sep 21, 2011 | 06:37 AM
twinturbogreg's Avatar
Originally Posted by mitsael
I got mine done at Jacks in CO and they did a great Job. I highly recommended pretty much everybody that own and evo around KC area they go to jacks.
I don't think you had your T-case rebuild by Jacks. I spoke to him a couple months ago and he did not rebuild them. All he could do was replace the seals. Was yours just leaking or was it your Tranny you had rebuilt? Your sig just says Tranny
Old Sep 21, 2011 | 12:27 PM
EvoX_BV01's Avatar
I had the exedy twin plate in there and replaced it with spec 3+ check the video on first page for the sound its making at 4th and 5th its just a whine, but in low gears when i give it gas and let go its like the engine breaks but theres a metal colliding with metal, one of my axles seals was replaced because of oil leak, what do you know i looked under the car and its still leaking, most likely the Tcase needs a reseal?
Old Sep 22, 2011 | 07:52 AM
mitsael's Avatar
Yeah it was my tranny not t case my bad! i should it specify. I do not think jacks does t -case for the X at least is not on the page. This is what i did to my transmission http://www.jackstransmissions.com/co...s/evox-rebuild
Old Sep 23, 2011 | 12:50 PM
EvoX_BV01's Avatar
damn that's not too expensive either! As of now the car is for sale. If I don't get the money I'm asking then ill buy a used tcase
Dallas J
Sep 10, 2019 11:45 AM
red2003evo8
14
Oct 13, 2007 12:31 PM
dryad001
62
Mar 2, 2007 04:45 PM
joon
Nov 7, 2006 09:38 PM
Chris@nolimitmotors
27
Jul 13, 2005 08:53 AM
