Turbo ??
Old Sep 28, 2011 | 08:29 AM
Orodi's Avatar
Turbo ??
I am new to evos so I am not 100% up on the mechanical side of things but to my knowledge the boost hits 21-23psi and then falls off to 15-17.
My question is will a MBC or EBC fix this so the boost will stay at the 21-23 mark or is this just the nature of the stock turbo/motor?
Old Sep 28, 2011 | 08:35 AM
Kracka's Avatar
That's just what's programmed into the stock tuning.
Old Sep 28, 2011 | 09:21 AM
Orodi's Avatar
How does the tune effect the boost levels?
Old Sep 28, 2011 | 09:26 AM
Kracka's Avatar
The ECU controls boost with two electronic boost control solenoids.
Old Sep 28, 2011 | 10:49 AM
Orodi's Avatar
Gotcha, so with a tune it will fix it? Do I need to replace anything? So far I have FMIC, UICP, LICP, CAI and Borla cat back.
Old Sep 28, 2011 | 11:00 AM
Orodi's Avatar
I was planning on doing DP and TP, WB and Boost controller. I want to stay on the stock motor and not totally kill the MPG. Mainly just a fun toy not get TOO serious.................yet
Old Sep 28, 2011 | 11:08 AM
Kracka's Avatar
Yes, with a tune you can run more boost. Are you planning on getting dyno-tuned locally? If so, I would also suggest a 3-port BCS to better control the boost vs. the stock solenoids, a testpipe/HFC, and an intake (or at least drop-in panel filter). Skip the 3-port if you plan on using an OTS Accessport map.
Old Sep 28, 2011 | 12:02 PM
Orodi's Avatar
Yes my tuner is 2 miles from where I live. 3-port BCS <---Boost Control Solenoid? What is the best brand for this? I have a AEM CAI. As far as the boost what is well within the safe limit 23-25psi?
Old Sep 28, 2011 | 12:20 PM
Orodi's Avatar
http://www.amsperformance.com/cart/g...-solenoid.html
Good?
Old Sep 28, 2011 | 12:22 PM
Kracka's Avatar
The Grimspeed one is fine, I have one and it's working as it should.
Old Sep 28, 2011 | 12:38 PM
Orodi's Avatar
Cool, ordered haha. So far I am up to $900 out of my 3k limit
JDM EVO 6
20
Dec 21, 2013 06:14 PM
gpfury86
Jan 7, 2012 07:31 AM
YogSaahoth
16
Sep 4, 2010 12:40 PM
charon2123
Jan 25, 2010 06:30 PM
rivz
11
Mar 11, 2009 04:57 AM
