Need to replace my clutch... any recommendations?
Old Nov 21, 2011 | 03:52 PM
  #31
STi2EvoX's Avatar
^Are you guys running any big sales for black friday?
Old Nov 22, 2011 | 12:32 PM
  #32
arghx7's Avatar
I don't get it.
Why hasn't anyone suggested he put another stock one in there?
Old Nov 22, 2011 | 12:35 PM
  #33
ETS Michael's Avatar
Sounds like a lot of work to have a clutch that will slip with minor bolt ons.
Michael
Old Nov 22, 2011 | 12:37 PM
  #34
arghx7's Avatar
he never said his clutch was slipping though or that he was launching it hard, or that he planned to put a lot of power through it
There has been some concern about various issues associated with aftermarket clutches. Seems like a stock one would be the best solution in this case.
Old Nov 23, 2011 | 10:53 AM
  #35
STi2EvoX's Avatar
I thought I had mentioned in my first post that my clutch is slipping, and that that's why I'm looking for a new clutch. Either way, I appreciate you trying to help, but the stock clutch is terrible and I wouldn't even consider putting that POS back in my car. It can barely handle basic bolt on and tune power, and burns more easily than any clutch I've ever driven on in any car - EVER. No thank you. I'm nervous about getting an aftermarket clutch and the issues that can go along with them, but I'll take my chances.
Old Nov 23, 2011 | 04:41 PM
  #36
HAHAV8's Avatar
Anyone who knows who to properly drive a manual will not have any issue street driving a full bolt-ons X. If you're drag racing, then yeah it won't last extensively, though.
Plenty of guys have luck running BBX Lites's, FP Green's, and EF2's on the stock clutch also, as long as you know how to properly drive a manual car, there should not be an issue as torque is very similar, if not less than a bolt- on stock turbo car.
With that being said, I would recommend replacing the OEM clutch with something better, depending on your cars overall goal.
Old Nov 28, 2011 | 07:57 PM
  #37
TheNEWB's Avatar
Originally Posted by STi2EvoX
Anyone ever run any of the Spec clutches? How do they compare to Exedy in quality and performance?
I had spec stage 2. Going to spec State 3+. The Stage 2 clutc was very forgiving but does not like tq. So built motor 2.3L killed it :-)
Old Nov 28, 2011 | 08:53 PM
  #38
Bardabe's Avatar
If I was to get together with the guys at RPS and produce a twin disk clutch that can hold good power, but be a little softer than stock so we don't burst CMC's who would be interested?
Old Nov 29, 2011 | 10:42 AM
  #39
scheides's Avatar
EvoM Moderator
ACT HDG6 with stock flywheel! I have almos 20k on mine, almost 40k on the stock CMC...25 drag launches or so...great clutch IMHO.
Old Nov 29, 2011 | 03:49 PM
  #40
EvoX336's Avatar
Spec is a really good clutch! I have the Spec stage 3 6puck
KillaYayo
May 10, 2017 03:03 PM
slebo3213
Oct 21, 2016 07:02 AM
mjev8
Mar 31, 2016 10:58 AM
snake20
Mitsubishi TC-SST Discussion
35
Sep 8, 2010 01:47 PM
dEdiYT11
15
Jan 13, 2005 07:17 PM
