New FP Ball Bearing Turbo
Old Jan 3, 2012, 10:34 AM
Semih321's Avatar
So I ordered mine and I should hopefully have it soon....does anyone have any dyno charts of these new turbos in action....I know its very new but I spent alot of money on this and I wanna see it in action even if it is not on my car.....any input is much appreciated.
Old Jan 3, 2012, 02:19 PM
mitsael's Avatar
In for some results! :-)
Old Feb 8, 2012, 03:40 PM
Dmwhite61's Avatar
Any news?
Old Feb 9, 2012, 06:21 AM
stokEd's Avatar
Is the only difference changing the thrust bearing out for a ball bearing cartridge? I thought this was being done for reliability, performance-wise the turbo will produce the same as the non-BB variant.
Old Feb 9, 2012, 06:23 AM
Kracka's Avatar
Yup, basically. Transient response will be a bit improved, but that's about it.
Old Feb 9, 2012, 09:41 AM
spdracerut's Avatar
Read:
http://www.motoiq.com/magazine_artic...-bearings.aspx
And:
http://www.motoiq.com/magazine_artic...bine-maps.aspx
Lastly:
http://www.motoiq.com/magazine_artic...p-details.aspx
Short version, reduced power loss of the ball bearing improves the overall turbine mechanical efficiency.
Old Feb 11, 2012, 08:36 AM
stokEd's Avatar
Originally Posted by spdracerut
Read:
And:
Lastly:
You are correct, but it's a very general statement and ultimately the differences between thrust/ball bearing Black variants will be transient response (spool) and reliability. Peak power is largely defined by flow and without modification to the geometry of the turbo (housing, wheels) both variants are going to yield the same numbers at peak. This being the case, expect the BBBlack (above say ~3500 rpm) to generate the same power as its non-BB predecessor.
Old Feb 15, 2012, 05:10 PM
EvoXAddict's Avatar
I'm interested to see some results also. I have an FP Red with full exhaust on my car now. Would the cost of pulling it and getting ball bearings installed be worth it for the quicker spool? How many RPM's quicker would it spool?
Old Feb 15, 2012, 05:27 PM
The__J__Factor's Avatar
^ Would not be worth it to me. Huge cost to change when spool is probably no more then 100rpm earlier if at all.
jrblackSE
Jul 13, 2012 12:07 PM
BenJ
Nov 18, 2011 02:51 PM
recompile
42
Jan 14, 2008 12:55 PM
speedomodel
Dec 30, 2004 01:57 PM
rhitme03
Jun 21, 2003 06:31 AM
Quick Reply: New FP Ball Bearing Turbo
