Transmission might be done...
So your saying those welds cant handle what you said it could. the welds are obviously terrible which let the pin back out and cause this problem . I think you should rethink your attidued and fess up to your bad welds before you dig your self into a bigger hole. If the welds were correct and your product would of held up to the extra power. Even Sheps told me over the phone that it sould of not done this if they were welded correctly.
I purchased a used trans of a part out thread on here and sent the trans right to shep ! Contact them, sometimes they have a trans around.... I am on my third trans lol this is the first one with the diff mod so im curious to see how it holds up. I wouldn't blame SSP for this, I would blame the previous owner for being cheap/lazy to do it the correct way
Btw I ordered a Sheps diff fully upgraded. If anyone has this same issue call them they have a good fix that helps with this.
The welds were MEANT to be surface tacks, NOT full structural welds. The intent was to use small welds to stabilize the spider pin and reduce the vibration/movement that causes the small retention pins that hold the spider pins in place to shear, hopefully preventing the shearing. Obviously it did not. However we did not want to damage the diff carrier by putting full structural wleds around the pins, in case it needed to be repaired later. The wisdom of this choice is born out by the fact that fully welded pins break the welds and back out as well. We did not know this until recently, but I have seen it for myself.
Obviously the pins move around and exert a great amount of force in their movement. This force is to great for ANY weld to take because of the inherent lack of flexibility in a weld. This same force is what breaks the OEM retention pins.
The way you are publicly blaming and accusing SSP is wrong. You have never had any dealing with SSP except when you called up here trying to get a free transmission. If you had taken the time to call here BEFORE buying the car, we gladly would have given you the cars history, and you likely would not have bought it. Thats on you, not SSP.
RallyDSM
Mar 19, 2017 07:05 PM
fireroasted
25
Dec 19, 2012 08:43 AM
