Issue with Under Hood Bushing 11' Evo X
Old Mar 4, 2012 | 05:17 PM
Krotondo's Avatar
So I went to install my AMS Gate bushing, no problem. Next up was some torque solutions under hood bushings. I noticed that the 08' had a different size so i made sure i ordered the ones for 10'+ anyways here is a picture of the shifter cables....
The first one (on the bottom went in no problem, next was the one in the back but the bushing is much smaller then the one they provided. Its the same size as the first one. Im sort of confused, did they send the wrong ones? Should have i received a larger bushing and a smaller one? Or does my car have the 08' shifter cables...
The part number on the package AWDmotorsports sent me is the correct # for MY11' but obviously only one bushing fits...
Any help guys?
Old Mar 4, 2012 | 07:26 PM
Snakes709's Avatar
So im confused, does it not fit in the cable or fit on the arm? I recently installed TWM's bushings and when i put it together (didnt know i had to sand the pin), got in the car and i had to use both arms to move the shifter side to side. So if its the pin your having trouble with, sand it...just like you should have for the first one.
Old Mar 4, 2012 | 07:55 PM
Krotondo's Avatar
Nope, the actual bushing is too large, in the picture, the bushing on the bottom is one of the new ones, they sent me (2) of that size, as you can see the the bushing that I'm holding in the picture is not the same size as the bottom one.
Old Mar 5, 2012 | 07:51 AM
jyamona's Avatar
you should have received one large bushing (the one you installed) and one smaller one. the one in the back is still smaller on 2010+
Old Mar 5, 2012 | 08:23 AM
Kracka's Avatar
Sounds like you were sent an incorrect bushing. Your picture looks identical to my 2010.
Old Mar 5, 2012 | 05:24 PM
Krotondo's Avatar
thanks for the info guys, called awdmotorsports, they are sending me the correct bushing!
Old Mar 5, 2012 | 07:50 PM
ionion's Avatar
just order a set for my 08 gsr.. hope they are the right size
Old Mar 29, 2012 | 11:52 PM
jkc213's Avatar
just got this today.... do i have the correct bushing?? my car is 2010...
Old Mar 30, 2012 | 08:09 AM
jyamona's Avatar
in what I can see in that ****ty picture, looks correct to me.
Old Mar 31, 2012 | 10:30 AM
jkc213's Avatar
installed this today, the middle bushing (pic) perfect fit.. but im wondering the third bushing, is it for 2008?? its smaller than the 2nd bushing..
LCS
Jan 19, 2016 05:23 AM
RallyartRob
May 2, 2011 08:25 AM
Golden
Jan 27, 2011 10:03 PM
GTS08
Apr 9, 2009 09:02 AM
adrynalinjunkie
Nov 26, 2007 01:50 PM
