Blown Piston Ring :(
Old Jul 4, 2012 | 02:50 AM
  #76
user 72082032's Avatar
Originally Posted by evoredy
I agree with what you said, but if the cylinder's were checked via a feeler gauge and ring gap method in multiple places OK, then he should be ok. The motor will be a tad loose and may consume more oil (but not too much more/1qt or less duing a hard 3000 miles) than stock.
So piston to bore clearance doesn't matter only ring gap
Did the oil jets and crank come out for honing?
Just asking.
Old Jul 4, 2012 | 03:04 AM
  #77
evoredy's Avatar
Just asking.
I'm hoping he just did a ball hone with OE serivce manual prescribed passes to clean it up. Anything else and the engine must come out of the car, go to a machinie shop, and go over .020 or watever. In which case, the block would have to be stripped of everything. Seems like he just did a drop in--OP corect me if I'm wrong.
You would take a piston compression ring and put it in at least 4 places in the cylinder and measure the ring gap to verify there is no "coning" of the cylinder bore. At those places, the ring gap should be the SAME. Any variances and the block is done. Place the lubricated ring in the bore and use a piston upside down and carefully press the ring down in the bore to get your test points. Not the best way, but it will get you up and running if an engine shop is out of the question and done carefully.
Old Jul 4, 2012 | 03:09 AM
  #78
He's using head studs now anyway so the block will twist when torqued up and pinch at the top without a torque plate hone anyway. Oh well.
Old Jul 4, 2012 | 06:24 PM
  #79
AJsGenerX's Avatar
We did a ball hone. All cylinder wall scuffs and scratches were removed. There is a deep scratch left in cylinder 1 but it was just above where the rings sit at TDC. The car holds perfect compression and is running flawlessly. I put 200 miles on the motor so far. Here are some pics:
Old Jul 5, 2012 | 12:47 AM
  #80
evoredy's Avatar
Good job man. Enjoy it and please use higher octane or dial the timing down this time. Recommend E85 or some sort of meth injection.
Old Jul 8, 2012 | 06:59 PM
  #81
Jookies's Avatar
Car's lookin great man, I'm happy it's up and running again!!!
Old Jul 8, 2012 | 11:54 PM
  #82
Vernon374's Avatar
Did you notice it going lean at all before you discovered the failure? Something that could have caused excessive knock? Test your gas to see if it was a bad batch?
Old Sep 28, 2012 | 06:18 AM
  #83
Showbizz41's Avatar
How's this car running now after a few months? How many miles?
khoyer
Dec 6, 2016 10:00 AM
AJsGenerX
Oct 16, 2012 06:22 AM
AJsGenerX
Apr 18, 2010 12:11 PM
superman105
Oct 28, 2009 03:36 PM
AJsGenerX
24
Mar 5, 2009 12:18 PM
