MXP exhaust
Old May 7, 2012 | 05:24 PM
Quang-Star*'s Avatar
MXP exhaust
anyone else running this exhaust? im having some issues with it. I want to know if anyone else is having the same issues. Please chime in!
Old May 8, 2012 | 11:19 AM
[raven]'s Avatar
what kind of issues are you running into?
Old May 8, 2012 | 11:44 AM
rattling... clearance. It's hitting my drive shaft and or subframe. I've tried literally everything so im just wondering if it's a defective exhaust.
Old May 8, 2012 | 10:28 PM
stokEd's Avatar
Have you checked to make sure your testpipe and/or mid-pipe is installed correctly? If either is installed backwards (and it happens!) you can run into clearance issues.
Old May 10, 2012 | 11:39 PM
yes sir! twice.. two different shops. I took measurements... the mxp test pipe is short. by about 1/2 inch. which pulls the exhaust forward a little bit. It's causing some major clearance issues i have pics to post shortly. Im in an email war with reps at mackin... they are now placing blame on AMS downpipe... which is just aweful!
Old May 11, 2012 | 10:32 AM
[raven]'s Avatar
Funny you mention that. I was reading a thread a while back that said the AMS dowpipe is a tiny bit shorter, and it would have clearance issues with certain exhausts.
Here's the thread: http://www.evoxforums.com/forums/showthread.php?t=37360
Old May 11, 2012 | 10:53 AM
[raven]'s Avatar
AMS also responded in that thread. I guess fitment can't always be guaranteed when mixing different parts. One solution was to weld in a pipe extension to the exhaust.
Old May 23, 2012 | 05:14 PM
Ok, so i ordered a new test pipe.. (AMS) everything is fine clearance issue is fixed. As it turned out the MXP test pipe has a angle that cause the clearance issue.
Old May 24, 2012 | 11:35 AM
[raven]'s Avatar
any clips? I've been looking into running this exhaust with a HFC and DP...
Old May 25, 2012 | 12:03 PM
WoODStOcK's Avatar
I have this exhaust on my car and love it! No fitment issues at all. So the earlier AMS downpipes had some sort of issues?
Old May 25, 2012 | 12:11 PM
[raven]'s Avatar
I don't think it was much of an issue. Just that putting different brand exhaust parts might throw one or the other out of whack just a tad...
Old May 30, 2012 | 05:00 PM
actually MXP's tp was faulty... they refuse to admit it... but the pipe has a weird angle that caused the clearance issue. You wouldn't know it unless you run the full set up. I had the MXP tp and MXP exhuast. I documented everything i even have detail pics of the clearance issue.
Anywho i swapped out the testpipe for an AMS one. ( same length as MXP resonated tp) Just one huge difference. NO weird angle, and everything clears. It's perfect now. My favorite dual exhaust on the market for the price.
Old Jun 26, 2012 | 12:01 PM
DreamsOfEvo's Avatar
I have installed about 5 mxp turbo back exhaust and have had no clearance issues it is probably ur downpipe
Old Jul 15, 2012 | 07:10 AM
blasian760's Avatar
my buddy was having problems with one couldnt fix it so he jus dumped it
Al B
Australian Forum
Jun 8, 2015 04:41 AM
Uhlyssa
Oct 11, 2011 08:02 AM
rdebow
Jun 29, 2009 12:27 AM
BUCKNAKED
Midwest Region
28
Jan 14, 2008 03:02 PM
termsheet
15
Jul 23, 2005 01:16 PM
