Need help with my clutch
Old Jul 3, 2012 | 09:00 PM
lalexl's Avatar
(***Excuse my english I'm french***)
Ok here is my situation:
I have a 2008 Mitsubishi Evo GSR
I buy the car with 38 000km (aprox 23k miles) last March and now I am at 43 000km ( approx 27k miles)
I put my car in 2 different drag session (3 pass the first day and 2 pass the second with a month between my 2 drag "session" and never use the launch control. I do launch around 4k rpm
On my first day on the 1/4 miles i did burn my clutch i realy didnt miss it. (some smoke came out from under the car and the clutch smell BADLY)
On my last drag session, only 2 run (makes 2 days now) i might have slip the clutch a litle since i smelled a very LIGHT smell of burn clutch.
At the end of the pm i drove back to my home and everything goes fine (5-10 miles) But, on the same day, i was on the Highway 65-70 mph 3200 and decide to pass an other car so i floor it.
The rpm make 3200 to 5000, my boost peak to 23psi right away but my car was not going faster. Then maybe, 2 sec after my rpm went down to 3800-4000 and I start moving faster and gaining speed.
After that i test and it did the same in gear 3-4-5
Today, 2 days after the problem is much more worst it do the same in 2-3-4-5 gear and i barely can't accelerate. I got the same acceleration of a 2000 hyiunday accent and even there i think the accent beat me on a 1/4.
I still got the OEM clutch
I've been told that the problem is my clutch and that she just slip. My friend told me my clutch is dead and that i have to change it.
Mods :
intake ETS
UICP ETS
LICP UR
Axleback TurboXS
Midpipe MeganRacing
Test pipe TurboXS
So what are you're though
Old Jul 4, 2012 | 10:22 AM
tehSteve's Avatar
well you are experiencing symptom #1
do a clutch drop test in 5th from a stand still and see if the car dies.
i would say just upgrade clutch & get a magnus evo9 cmc conversion kit for the X
aftermarket clutches can blow the master cylinder
and your English is very good btw!
Old Jul 5, 2012 | 01:20 PM
Semih321's Avatar
your clutch is done....it will just keep getting worse until you will not be able to move the car at all...stop driving it asap....order a clutch, flywheel, and a new CMC.
Old Jul 6, 2012 | 06:06 AM
lalexl's Avatar
I already order a new clutch (competition clutch stage 3)
I also order the AMS reinforcement ring.
And I will keep my OEM flywheel and just have it resurface
Old Jul 10, 2012 | 09:40 AM
mac11wildcat's Avatar
For the cost why not just get a new master cylinder? The ring doesn't guarantee anything. My experience goes that placing a bandage one place makes for a boo-boo in another.
David Buschur
114
Feb 4, 2013 09:02 AM
Insanity Evo
May 31, 2011 05:11 PM
jrsimon27
Aug 2, 2008 09:03 PM
JamonEVO
Mar 21, 2007 05:43 PM
ltwayner
Jan 25, 2005 09:06 PM
