Good grief fp green/red!!!!!
Old Aug 22, 2012 | 05:24 PM
Maverickvf84's Avatar
Originally Posted by cdmassee
This would be a great debate.
The Green has the "new" 65mm revision of the high efficiency 67mm turbine wheel used in the Red.
so physics says that the Green spools faster. but then again...
Oh snap...u c i didnt even know that!!!!Hmm...I should but what about the pwr output!?Not that I care about top end pwr but it would b nice...
Old Aug 22, 2012 | 05:59 PM
Snakes709's Avatar
go green on e85 if you have it. If not, go Red. I had a bb FP Red and ****ing loved it. However since i popped my engine, im building to a 2.2L and i sold my Red so i can pick up a FP Black.
Old Aug 22, 2012 | 06:05 PM
cdmassee's Avatar
How much power are you talking about?
the green is easily capable of 400+ hp on pump gas as the others said.
With E85 460+
your car would be a blast. Especially with the zero lag.
But if you dont have Ethanol, and are going to want more and more power after awhile,
then the red might be for you?
Old Aug 22, 2012 | 06:14 PM
shrtstuff89's Avatar
I have my e85 2.3 fp green s2's springs 3.5" IC full piping 3" tbe so on so forth. Corrected, i made 510/505 up here a mile high. uncorrected was low 400's. You wont see the tq i have, but youll see it go up. Especially with e85. Now whenever the green goes, ill be going to red or black cuz i just like seeing the look on ppls faces when a 4 door sedan just rapes
Old Aug 22, 2012 | 06:48 PM
OK OK now im leaning real heavily on the Green side!!!!!!And all this talk about e85 is really gettin my attention...now my next question...I heard a rumor that a turbo like the FP Green becuz of it torque and quick spooling pwr can easily break engine components...True/false?
Old Aug 22, 2012 | 09:06 PM
Nickzorz91's Avatar
You said you want to be able to beat a ZL1... you'd probably need a red or black on e85 for that.
Old Aug 23, 2012 | 05:30 AM
EvoX2NR's Avatar
Yep, quick torque shots can throw rods like horseshoes...
Chetrickerman just converted to a red from his green that he used to have. Maybe he will chime in on this...
Old Aug 23, 2012 | 05:40 AM
That's the part that concerns me...I don't want to have a stupid amount of torque...But hopefully I hear from ppl who have made that switch!!!!that would b a big help!!!
Old Aug 23, 2012 | 12:11 PM
chetrickerman's Avatar
Veteran: Army
The green definitely lacks the top end that the red has.
Also, you will notice the lag with the red, but you wont actually feel it.
Going off of your OP, the green will suit your needs. But eventually the green just wont be big enough and you will want a red.
The green on E85 will get you 450 whp, but a red on E85 will get you 500 whp.
Btw, if by low end torque you mean torque to daily drive the car around city, then the red will give you plenty as long as your MIVEC is tuned well
Old Aug 23, 2012 | 01:26 PM
johnnnyjeans's Avatar
red with a quick spool tune. done.
Old Aug 23, 2012 | 01:46 PM
Chetrickerman, I heard u switched from a Red to Green so u might b the biggest help...When u and other ppl sayvthe Green lacks pwr up top...Is it from the concept that its lacking less then the factory turbo up top or is it the same or more?
I really have no problem getting a Green even if I will want more pwr with a Red.What I really don't want is the extra lag...but it sounds like thats inevitable with the Red but ill worry about that later...and my major fear is the talk that the Green is more likely to cause damage becuz of its quick spool...any thoughts?
Old Aug 23, 2012 | 01:50 PM
BlueX702's Avatar
You posted about ZL1 and GTR..... I think you would want something bigger than a green. I have a red and yes there is slight lag, but once boost kicks in and it pulls all the way to redline you kind of forget about it.
Old Aug 23, 2012 | 02:36 PM
Levar's Avatar
Veteran: Army
I take it that these posts are for the EVO X, right?
If not, I will have some back to back tests done between the FP Red and EF4 on 91-octane and E85 with a LR 2.4L engine hopefully by the end of next week.
Right now, I am making full boost with the FP Red on 91-octane under 4,000 RPM.
Old Aug 23, 2012 | 02:41 PM
Veteran: Army
The green definitely has more power up top that the stock turbo.
Just make sure you have a good tuner and it will be fine
Old Aug 23, 2012 | 04:07 PM
Trail Slide's Avatar
what states have E85? I am in jersey and have literally never seen the stuff..
