Drive train whine or what?
Old Aug 20, 2012 | 12:17 PM
knucklez's Avatar
Ok, I know of the first gear whine and my GSR definitely has that when the car is decellerating with the clutch pushed in however i've started to notice that my 3rd gear has started to produce that whine when accelerating around 3k. Goes away when I push the gas a little more.
Hopefully it's nothing too crazy, I have read about evox's having gear whine especially in first gear. I'm going in for my 1,000 mile oil change this week, any other fluids i should swap out?
The car has 1235 miles and has never been launched or driven over 100 mph.
Old Aug 20, 2012 | 12:28 PM
rcheung's Avatar
can you post a clip of the noise?
Old Aug 20, 2012 | 01:11 PM
knucklez's Avatar
delete. video posted on main post.
Old Aug 20, 2012 | 01:12 PM
knucklez's Avatar
Old Aug 20, 2012 | 01:14 PM
Hotevo3's Avatar
Knucklez your 1st to Reverse is very common and quite a few Evo's struggle with it. Here is the sticky about the fun transmission issues we fight
https://www.evolutionm.net/forums/ev...on-thread.html
Old Aug 20, 2012 | 01:21 PM
knucklez's Avatar
I've contributed to the thread in the past
My notchiness from 1-2 and 2-3 is a lot less now due to breaking in the car and getting a weighted shift knob.
This damn noise though, it's driving me crazy.
Old Aug 20, 2012 | 01:31 PM
Hotevo3's Avatar
Just so you have something to compare to, mine seems to only slightly whine when I'm decelerating in 1st only when I'm off the clutch. As soon as I press the clutch to switch into second or come a complete stop no noise. Mines an 08 Evo 100% stock 42k miles <just bought mine 2 months ago
Old Aug 20, 2012 | 02:46 PM
EvoG8r's Avatar
I have a 2011 with no gear wine. Maybe have the gear oil tested by a lab?
Old Aug 20, 2012 | 02:48 PM
knucklez's Avatar
I honestly don't know what the problem is and I am clueless because the car is brand new.... I'm wondering if any of you guys know what the problem might be (if there is one) by looking at the video I posted.
Old Aug 20, 2012 | 05:57 PM
rcheung's Avatar
It sounds very similar to a transfer case whine although when they start to fail its usually around 60mph that the noise begins. It usually doesn't sound like that until it gets worse. It didn't look like you went that fast in the video. Does it get louder at around 60 mph?
I read some 2010 and 2011 evos had an overfilled transfercase. When that happens and too much pressure builds inside the case, there is a bleed valve that squirts most of the fluid out and there is not enough fluid left in the case to keep things lubricated properly.
Of course it may not be your issue at all but my guess is the transfer case. I see you're going to the dealer anyway. It would be a good idea to have them check the tcase and tranny fluids while they have your car.
Report back what happened when you get your car back.
Old Aug 21, 2012 | 09:27 AM
knucklez's Avatar
It doesn't get louder around 60 mph. The sound only appears at specific rpm's in certain gear. I'm hoping a simple fluid change will get rid of it.
The big question is should I take it to South Coast or HB?
Old Aug 21, 2012 | 10:05 AM
impact blue's Avatar
I personally would just do it myself if you have the time. Make sure you have a beater car to get you back and forth in. Pm me for details
Old Aug 21, 2012 | 10:30 AM
wicked white14's Avatar
Dude, pretty sure it is typical drive train noise. I have a '08 with 38,XXX and had the fluids changed not to long ago.............. the car has always ahd an audible moise around 3K....go slower or faster and it just goes away...........These cars make sooo much noise it is crazy.........and if you have OCD like me I am always pulling **** apart to find nothing.
Old Aug 21, 2012 | 11:08 AM
knucklez's Avatar
Yeah, I definitely do have OCD and I found gear whines (that sound very similar to this) on all my previous cars including my 350z and lexus rx330 (yes, i know, lmao). My dad also thinks it's normal transmission whine however I do not want to rule anything out just *incase*.
I literally spent a whole day sunday checking under the engine hoping it wasn't the turbo and I have definitely ruled that out. I will still have the stealership check it out this weekend.
Thank you for your reply, puts my mind at ease knowing that i'm not the only one getting these random transmission whines.
eddy5201314
Apr 25, 2017 06:56 PM
evo837
May 12, 2015 02:16 AM
EMonz57
Apr 22, 2014 09:03 PM
yahu
48
Apr 13, 2010 07:09 PM
mattz09
Apr 6, 2010 01:40 PM
