Best BOV for a stock turbo?
Old Sep 16, 2012 | 12:12 AM
darxide's Avatar
i have a '09 Evo X with full bolt-ons, i changed the stock BOV and got the turbo-smart which is amazing! but i think its surging alot. its on 50/50 mode (VTA/Recirculated). Any solutions? ideas or thought? people with the same problem?
Old Sep 16, 2012 | 07:39 AM
Jookies's Avatar
Any VTA for a car with a MAF sensor is not good. Full recirc is the way to go. If it's surging a lot, the spring is probably too stiff.
There is no such thing as an 09 evo x....
Edit: just saw that you were in another country... I may not be correct about there being no 09 evo x haha
Old Sep 16, 2012 | 08:02 AM
Hiboost's Avatar
Best BOV for a stock turbo = the stock BOV crushed halfway.
There, I just saved a ton of money for everyone!
In all honesty the best drivability is with the stock BOV, crushing it carefully and evenly in a vice to where the boost nipple moves about halfway down to where it would touch the body of the BOV seems to be perfect.
This will improve the boost holding from about 25 psi to about 28 psi in my testing with a compressor and timing how long it takes to bleed off pressure. So unless you plan on running super high boost from 4000-5000 rpm via E85 or foolishly running more than 28 psi on pump gas, you really don't "need" an aftermarket BOV that leaks less but causes potential drivability issues.
I recently ran 11.96 @ 114 mph in the 1/4 with the stock turbo, stock bov (1/2 crushed), stock intake/filter... car runs like a champ and is the perfect daily driver.
Old Sep 16, 2012 | 04:27 PM
Kracka's Avatar
Go 100% recirculated, see how that helps, then if you still want more loosen the adjustment spring a bit (assuming its adjustable).
Old Sep 17, 2012 | 10:08 PM
darxide's Avatar
the hell with it! i got an Evo X and i dnt care if it was a 1969
And i'll try to get the stock BOV back, i think the garage that i deal with still has it. i hope he doesn't nag too much and let me change it. ((he has issues lol))
Thanks guys for the Help!
Old Sep 17, 2012 | 10:16 PM
scheides's Avatar
EvoM Moderator
Crushed stocker or Cobb BOV. APS Twin-vent.
Old Sep 19, 2012 | 12:36 PM
ogrenator's Avatar
I've got the dualport that you have...best way to tune is turn it all the way so its on the hard setting and then keep driving and softening the spring...I have no surge whether i'm running 50/50 or full recirculated..good luck dood
oh by the way im sure you already know it gets hot as $hit so be careful lol
Old Sep 19, 2012 | 01:32 PM
Ev0ikon's Avatar
http://www.turbowhistler.net/turbo-whistle/index.htm
Then put the stock valve back on. You get that sound and not $%^&Up your drivability.
krazybai
Dec 22, 2016 12:54 PM
Bananayellowevo
Nov 30, 2016 07:07 AM
yositoco
For Sale - Part Outs
10
Jun 14, 2016 04:50 PM
06EvoIXmr07
Jun 4, 2016 12:09 PM
Jie-EVO
Mar 25, 2007 07:07 AM
