Fuel system upgrade question
Hello. I'm in the process of upgrading my fuel system but first i wanted to do some research. In the process, I've heard of times where peoples fuel pressure would be too high with upgraded fuel pumps. I was wondering if this would be the case if I ordered the Blaqops kit with either the DW300 or Aeromotive340? Also, has anyone got feedback for the MAP 1000cc injectors?
IIRC, you're planning on going with the MAP EF2. Pump gas or E85? If pump, you will definitely not need a pump that large, I recommend the Walbro 255HP since it will give you no over-run or excessive pressure problems. I have never tried MAP's injectors, but they *should* be similar to my ID1000's since they start out as the same Bosch core. That said, I only personally recommend the ID1000's since I've had such fantastic luck with them (start, idle, and drive as smooth as stock injectors).
ChicagoEvo9
Feb 5, 2014 03:30 PM
evoballer
Feb 15, 2012 06:49 AM
ilikeppie
10
Feb 21, 2011 06:24 PM
