flapping noise after boost
Old Nov 14, 2012 | 05:29 AM
Shirish Agarwal's Avatar
I have 2008 EVO MR complete stock. Recently have started hearing some flapping noise ( I dont think i noticed it before) some flapping noise. If i drive it on boost / WOT for sometime then drive slow I am able to hear it. It seems to come from hood and can be heard only at very slow speed (20-30 mph). Any suggestions?
Also I connected OBD2 diagnostic and saw that my car reaches a maximum of 18 psi. Is that normal for a stock EVO or should it go more.
I am new to turbo's and this car so learning about it everyday.
any info is helpful!
Old Nov 14, 2012 | 06:02 AM
ILuvJDM's Avatar
edit: wait so you hear the flapping noise after you're back to normal driving? (out of boost) or do you hear the flapping noise at full boost? (wastegate operation)
Old Nov 14, 2012 | 07:00 AM
vegittoss15's Avatar
You should be hitting a bit more peak boost.
Old Nov 14, 2012 | 07:17 AM
Slickonice's Avatar
My buddies evo 8 was making some noises and it turned out to be the crank pulley was warped. You could actually see it wobbling around. And yeah, the bolts were tight. Sure its not coming from the belt area? Hope you figure it out!
Old Nov 14, 2012 | 07:19 AM
I hear the flapping noise after Boost , when I am driving normal without any boost.
can the low boost an issue with boost leak??
Old Nov 14, 2012 | 07:23 AM
Slickonice's Avatar
My brothers wrx has some light modifications and an aftermarket recirculating BOV. His bov is actually making what I would call a "fapping noise" during boost at WOT. His bov isn't holding boost at +19 psi very well. You can see the boost taper down more than it should. Did you try a boost leak test?
Old Nov 14, 2012 | 07:25 AM
have not yet tried boost leak test. its completely stock so i was hoping it will be fine. but if 18psi is less then that can be an issue.
Old Nov 14, 2012 | 07:30 AM
Slickonice's Avatar
Well if it's not really doing it during WOT maybe its not boost related. Is everything secure in your engine bay? I know on my evo it came without the top cam pulley cover and a wire was hitting it making some noise.
Old Nov 16, 2012 | 05:34 AM
yea.. everything seems to be in place.. Its just very light fluttering noise at 10 mph or so.. Dont know if its normal or what.
Password_Vic
Oct 31, 2016 01:56 PM
TxFAkuma
Aug 12, 2015 01:21 PM
Sev
Jun 6, 2011 03:20 AM
godmiller10
Feb 5, 2008 01:21 AM
mystang97
Automotosports - Illinois
Dec 12, 2005 10:16 PM
