Problem after installing AMS gate selector bushing
Old Jan 27, 2013 | 06:53 PM
thejumpoff's Avatar
I just got finished installing the bushing and after putting everything back together on the rocker arm, I ran into the issue of the 2 12mm bolts not lining up correctly with the threaded holes.
I've attempted to try either side first, hooking up the vertical bushing first, hooking up the vertical bushing last, reassembling the rocker arm, and readjusting the lock nut on the rocker arm. I don't feel like the gate bushing can be removed once it's set so I feel that that's out of the question. Not sure what I did wrong and I'm trying to get some suggestions/feedback. Have any of you guys ran into this issue?
Old Jan 27, 2013 | 07:17 PM
DocBoz's Avatar
wiggle the stick a little and see if that bracket will move.
Old Jan 27, 2013 | 07:27 PM
thejumpoff's Avatar
I've tried that. The white piece that sits in between the shift link prevents it from moving any more.
Old Jan 28, 2013 | 11:03 AM
Kracka's Avatar
Bolt it down before attaching the shifter cables.
Old Jan 28, 2013 | 12:11 PM
thejumpoff's Avatar
I've tried that, but when the rocker arm is attached, the small white piece that moves the arm up and down is already seated and prevents the bracket from shifting.
Old Jan 28, 2013 | 12:33 PM
Kracka's Avatar
I think you're doing something wrong here. Take it all apart and try again. If memory serves, there should be plenty of wiggle room when installing.
Old Jan 28, 2013 | 12:54 PM
thejumpoff's Avatar
Yea, I'm planning to try it again after work. Is possible to install the bushing in the wrong direction? Even then, it doesn't look like it should cause THIS much of a install issue.
Old Jan 28, 2013 | 12:59 PM
Kracka's Avatar
Did you follow their included instructions?
http://www.amsperformance.com/cart/a...shing-kit.html
Old Jan 28, 2013 | 01:08 PM
thejumpoff's Avatar
Yea, even double checked it against the TWM install instructions as well. This is why I'm so confused.
Old Jan 28, 2013 | 01:33 PM
Kracka's Avatar
If you can't figure it out tonight post some better lit pictures of everything and I'll take a look tomorrow morning.
Old Jan 28, 2013 | 02:23 PM
Scottr126's Avatar
By the looks of things the brass bushing isn't pressed all the way in.
Old Jan 28, 2013 | 04:38 PM
thejumpoff's Avatar
Got it! Thanks guys.
Scott, I'm not sure if that was it but I ended up disassembling everything and cleaning it down again and then re-greasing everything. Torqued the nut and resat the entire assembly -Somehow it worked.
Old Jan 29, 2013 | 05:40 AM
Scottr126's Avatar
Yah sometimes you just have to work it in a little bit. The brass bushing is somewhat self lubricating so after moving a bit it will smooth out.
Old Jan 29, 2013 | 06:43 AM
thejumpoff's Avatar
Thanks Scott. So it should be tight at first and then smooth out over time with driving?
Old Jan 29, 2013 | 06:47 AM
Scottr126's Avatar
Yes.
GraphiteMRevo
Mar 23, 2020 07:29 PM
brett@evogb
Apr 20, 2017 10:02 AM
C3L1CA
Mar 9, 2015 11:09 PM
thejumpoff
For Sale - Part Outs
Nov 2, 2013 04:46 PM
PDXRalliArt
Jun 25, 2004 01:16 PM
