Evo X boost leak test help!
Old Mar 15, 2013 | 02:05 AM
CounterConcept's Avatar
Hey guys my Evo feels disgustingly slow, I suspect I have a boost leak. So ima order a boost leak tester online that connects to the OEM turbo 2.75 inlet. My car is mostly stock just an injen intake w/ UICP and a greddy exhaust for performance mods. It just started to feel really slow after I got it back from the dealership for a transfercase replacement, I feel like they might have left a hose or coupler loose.
Now this is my first ever turbo'd car so I wanna make sure I do things right the first time. Once I hook up the tester to the inlet are there any hose I should disconnect before I begin to pressurize the system? I heard that I'm supposed to open up the oil cap is that true? Also what should I expect when I do this test besides gray smoke for a little bit after the test is done??
(I'm keeping my fingers crossed hoping its a simple boost leak)
Any pointers, help or info is greatly appreciated.
Old Mar 16, 2013 | 03:10 AM
Anyone? Bump.
Old Mar 16, 2013 | 11:25 AM
joeyhauser's Avatar
I didn't remove the oil cap and I also didn't have any smoke afterwards. I think they say to take the line off that goes from the intake to the valve cover and plug the port on the valve cover that that line goes too. At least that's what I did and had success.
Old Mar 16, 2013 | 12:59 PM
Ya i heard that too! I know exactly which hose your talkin about. So just unplug that? And what did u use to plug that port? I'm nervous of doing this and messing something up. I won't go past 20 psi I should find a leak with that pressure.
Did u connect yours to the turbo inlet of just to the intake by removing the cone filter?
Old Mar 16, 2013 | 03:56 PM
joeyhauser's Avatar
I removed the intake completely. Then hooked the tester to the turbo inlet. I just used my finger to cover the port. And yeah, 20psi should be enough to find the leaks if there is any
Old Mar 17, 2013 | 01:57 AM
Lol k cool I'll try it with my finger also. I'm hoping its a boost leak and not anything major. Wish me luck ill be performing this next weekend for the first time!
Old Mar 17, 2013 | 08:36 AM
joeyhauser's Avatar
Well after you get this sorted out, Paypal me $50 as a gift for my services
Old Mar 19, 2013 | 09:29 PM
xezerax's Avatar
Have a friend spray some soapy water around your connections, it'll help you spot minor leaks around couplers and what-not.
Old Mar 20, 2013 | 03:18 AM
Lol u wish!! I'ma gift you 1 dollar hahaha! I will be performing this on Sunday! I'm stoked cuz ima replace all the couplers to red so they match my valve cover and put t bolt clamps.
Old Mar 20, 2013 | 03:20 AM
Yea thanks dude! Ima for sure use soapy water to find leaks, I'm actually curious too see how big or how many leaks I have.
Old Apr 5, 2013 | 12:14 AM
mygsx's Avatar
Question
Did any leaks come about from testing? Thanks.
Old Oct 7, 2017 | 09:43 PM
menchies123's Avatar
Hi! I currently drive a 2008 evo x and want to see if i have a boost leak. I found this
http://turboboostleaktesters.com/evo-10-x-stock-uicp/
online and was wondering if you bought something similar?
Thanks!
KJS
Jul 25, 2017 02:27 PM
pistons4550
Jan 13, 2017 11:35 PM
4b11slayer
15
Oct 22, 2016 09:09 AM
Shaun@AWDMotorsports
AWD Motorsports - Florida
20
Jun 14, 2016 10:39 AM
commbubba19
May 9, 2016 08:15 PM
