Evo X no top end
Evo X no top end
I'll get to the point. Low end seems decent.. right up until about 5k or so. I feel the push from the boost kicking in but right around 5k mark it feels like its dropping off (kind of like if you have a bad clutch) and then all of a sudden the push picks up again but the power curve feels like its flattened out on anything about 5500.
I swapped the headlight and fuel pump realy but the problem remains. I checked for boost leaks as best I could but found none.
One of the peculiar sounds from the engine is kind of like its a low power 4 cyl reving high and chocking for power.
Thoughts on what to look for next, has anyone else had this problem. Car is all stock with the exception of an agency 2.5 charge pipe and stage 3 comp clutch w/ kevlar ceramic disc. It also seems to be inconsistent running a legacy GT I do pretty well. Today running an accord (following, it took forever to make up 4 car lenghts winding it out to 7500).... I know its embarassing but if I didn't want to fix it I wouldn't be posting.
BTW.. new plugs less than 10000 miles ago.
Fireescape
Jul 4, 2016 11:18 PM
proverb
Lancer How Tos / Installations
Sep 24, 2007 11:38 AM
