Help picking parts for 450 awhp build
So my goal is to hit a flat 340 tq curve and have 450 awhp
Ets v2 quiet
Bbx full
Ets recir downpipe
Ets test pipe
ID1000 injectors
Ams upper IC pipe
synapse bov
Ets intake
Ets 4 inch intercooler
Aem failsafe gauge in case the fuel relay fails or fuel regular hose leaks
Conservative 93 pump gas tune
Water meth kit for safety (not sure which kit and tune will run fine without it)
What do y'all think?
Would I need anything else?
I'm trying to keep the stock block reliable for a few hundred thousand miles
Ets v2 quiet
Bbx full
Ets recir downpipe
Ets test pipe
ID1000 injectors
Ams upper IC pipe
synapse bov
Ets intake
Skip the full exhaust and spend the money on a bigger turbo. Just make sure you get downpipe / test pipe. My car made 420whp with these mods. Maybe throw meth on it if you want a little more boost.
Dominator 2 Turbo
Deatschwerks 850cc Injectors
Walboro 255LPH fuel pump
AMS Short Ram Intake
Ultimate Racing Widemouth Downpipe
Ultimate Racing Test Mid pipe
Ultimate Racing Upper Intercooler hard pipes
Dominator 2 Turbo
run a
fp bb red
AMS tpms cams
1300 ids
intake upper lower IC pipes
AMS IC
Full 3 inch exhaust with TP
AMS wide mouth DP
boomba Fp with 340 aero.
exedy twin
AMS clutch MC
youll make 450 easy with room to spare. i say get bigger injector because when you hit 450 youll want 550 the 650 then 1150 lol .
fp bb red
AMS tpms cams
1300 ids
AMS IC
AMS wide mouth DP
exedy twin
AMS clutch MC
2.2 L stroker kit from cosworth
High flow piping e.g. Test pipe, intercooler pipe, straight pipe, etc...
Bigger injectors for e85 capability
AMS intake and 4"FMIC
Cams
If you get the stroker kit you should be able to pull off 450 whp on stock turbo running on e85 and some fat *** injectors. You would need some tuning for this set up. The benefit of putting a stroker kit is that of you decide to put on a bigger turbo, your power output would skyrocket by almost a 100 hp (assuming you mess with the exhaust manifold and install the ARC intake
Cams
Anything over 350 whp and its recommended that you should get bigger injectors. 450 whp, you def need bigger injectors, even if you cut boost. Now why do you wanna cut boost on fp red @ 23 psi? If you're gonna run 23 psi you might as well run the stock turbo with a wastegate upgrade so the boost doesn't leak out
They drop boost before hitting redline, e.g. if you have it set to 19 psi like most 2008 models it will drop to 15 psi on redline. More recent models are set to 21 psi but they still drop pretty bad
timmycat
Oct 25, 2016 03:49 PM
Shaka oNe
For Sale - Cars For Sale
Sep 15, 2015 07:10 AM
brandon1304
45
Oct 29, 2009 07:57 AM
