Porting stock turbo?
i had a ported turbo before i went with a map ef4 if your looking for almost stock spool get a ef 2.5 full porting and coating but stay away from the anti surge no need for it. This turbo will get you to 400 on 93 and 420 450 on e85 just you have to watch your torque. Like everyone is saying if you have the turbo off might as well do it right the first time. Im still on stock block and im on a ef4 but i no im going to build in the future. If it was my car and yur only looking for 400 deff 2.5 look in the dyno section Kracker has one.
My tuner actually is delaying spool on the stock turbo to prevent unnecessary heat soak (stock IC) and honestly i like it a lot better than full boost at 2900 rpm like most tuned stockers. It seems more streetable and my power doesn't drop off past 6k. I'm hitting ~24 psi at like 3300. Max psi is 26 and tapers back down to 23 at 7k.
My main concern with choosing a different turbo is to maintain spool up characteristics mentioned above, but at the same time i would only consider a ball bearing turbo. My purpose behind porting the stock turbo is to minimize torque drop off past 6k rpms. Plus it seems cheaper than dishing out 1500 on a new turbo.
Awesome info, thanks. Would you happen to have before/after dyno's of the ported stock turbo? And perhaps a dyno overlaying ported stock vs your ef4?
MAP ef3 ftw. The lag is not all that bad for street use, plus it will keep the torque spike down if tuned properly and hold boost all the way to redline. That way you won't ventilate the stock block. Stage 2 cams, upgraded valvetrain, injectors, and fuel pump and you're in business. Again, TUNED PROPERLY!!!!
YFZracer32
15
Mar 22, 2021 10:50 AM
jj_008
70
Mar 29, 2006 08:34 PM
