Kinugawa 25g turbo thread for Evo X
Man the nightmare continued.. the studs broke.. seems that the threads where beyond stripped.
At one point a bolt shot off the turbo and destroyed the heatshield!
I was out of commission for 4 days.. waiting on stronger studs, the mechanics had to take apart the manifold twice after 2 bolts sheered off. long story short the exhaust manifold from the turbo had to be retapped to 11mm. ( see pics)
The UICP will need to be re-done ( see pics below had to hack up the UICP and it still doesn't fit right) .
I will most likely get a heatshield put in and also put some cam sensor heatshields in as well.
Overall the turbo is working as stated..
I will never be a guinea pig again , I do not suggest this kit if you want a true plug and play solution!.
If you don't mind some fabrication , then go for it!
Some added pictures:
The bolts backing out I think that was probably an install error..
which got exacerbated. ( Thats not the turbo's fault or Kinu)
But there is no excuse on the oil lines and not have an outlet that fit the stock location.
The only thing "Stock" of this turbo is that it fits on the stock manifold.
I am going to enjoy my car for a bit before I put it on a dyno lol
When are you going to make the trip up to Orlando?
I didn't update the thread.. But stupid me did something real bad..
I spun a bearing ( unrelated to the turbo though)
It was called stupidity and downshifting to 2nd from 3rd @ 7500RPM.
the good news is that my spare block is good to go , no damage done to the block itself.
So I might slowly build it to support over 1000hp ( I like overbuilt blocks) and eventually in the next year or two drop it back into the car :0
