Ever boost
Old Nov 12, 2013 | 03:26 PM
Kevin-evo-x's Avatar
Ever boost
Hi so I just got an evo x gsr and the previous owner put so mods on in !! So they are
ARC AIR BOX
HKS LOWER INTERCOOLER PIPING AND BOV AND 3" upper intercooler piping no boost controller so I re plugged it the way it comes from stock as much as I could do mods and I also tried a manual boost controller but no success can someone help me to know as why I'm over boosting !!!!
Thanks
Old Nov 13, 2013 | 06:27 AM
Jake.barratt's Avatar
To use a boost controller you will require a tune for it or you will just keep over boosting.
Old Nov 13, 2013 | 06:41 AM
prowakeskater's Avatar
get a tactrix cable and pull the rom. Make sure the vacuum lines are all connected correctly and do a leak test. you can send me your rom and ill touch it up
Old Nov 13, 2013 | 08:47 PM
evolved0414's Avatar
Make sure your vacuum lines aren't backwards from the boost controller. Double check that as that would prob be the main culprit.
Old Nov 19, 2013 | 10:29 PM
I double checked the vacuum lines and the look like they in the correct place but still over boosting is it because of my mods ? And what is the cause
Old Dec 1, 2013 | 11:51 AM
sparky's Avatar
What brand of MBC is on there? How are the hoses hooked up?
TouV
24
Sep 28, 2014 01:32 AM
phatboy
Evo X Dyno Results
Nov 13, 2011 03:13 PM
MR EVO 9-NJ
E85 / Ethanol
17
Sep 5, 2009 01:43 PM
idanoclo
Mar 17, 2009 05:56 PM
