stock evo hits 30 psi!!??
Old Nov 22, 2013 | 11:20 PM
498001061's Avatar
I was shocked by my log result.. In the first run, the boost pressure spikes 24 psi, a bit of high but acceptable due to low temp. But in the second run it hits 30 psi.. My car is a bone stock 2011 EVO X GSR.. Anybody seen this before and know why? Please help!
Old Nov 23, 2013 | 06:28 AM
Jake.barratt's Avatar
hmmmm are you sure its stock? Did you buy it new or used? Also I would check if you have a boost controller.
Old Nov 23, 2013 | 06:33 AM
zanelefko's Avatar
if so you got a factory freak there my friend.
Old Nov 23, 2013 | 09:26 AM
nikmoretto's Avatar
mine is hitting 30psi...4th gear, I have a cobb stage 1+ ots tune with aem intake, ams intercooler...now it was -30 outside, I believe this is my problem...someone chime in please!
Old Nov 23, 2013 | 10:26 AM
Iowa999's Avatar
Was boost being measured directly or estimated from air-flow, etc?
Old Nov 23, 2013 | 12:11 PM
nikmoretto's Avatar
was watching my boost gauge built into my APv3...doing a log
Old Nov 25, 2013 | 06:23 AM
nikmoretto's Avatar
anyone?
Old Nov 28, 2013 | 10:34 PM
498001061's Avatar
I got right numbers by RAX fast logging. Thank you for relies!
Old Dec 1, 2013 | 06:59 PM
sparky's Avatar
What is peak boost level supposed to be on a totally stock USDM Evo X, anyway?
Old Dec 1, 2013 | 07:04 PM
sparky's Avatar
Originally Posted by nikmoretto
mine is hitting 30psi...4th gear.....now it was -30 outside, I believe this is my problem...
just to clarify, was ambient air temp -30* F, or 30* F...I just want to make sure.
A872B
Jun 7, 2017 08:52 AM
4b11slayer
Nov 10, 2016 07:57 PM
REVOlution X
36
Oct 16, 2012 08:59 PM
sobo
Sep 28, 2011 11:28 PM
PlanoEvo
E85 / Ethanol
11
Aug 19, 2010 09:21 AM
