engine won't turn over
Old Dec 31, 2013 | 02:33 PM
MurderedOut09's Avatar
Ok here's what's going on, my oil sensor broke so I had to replace it. In order to get to it I had to take tge radiator/fans out and had to take the intake manifold out to gain access to it. I replaced it and put it all back together. And now the car won't turn over at all...? I've checked all connections 3 times everyeverything is where is goes. Battery is good and has plenty of cca. I don't get it? I've looked over all fuses even checked the starter and it kicks on when powered. Can anyone help me at all please?
Old Dec 31, 2013 | 02:48 PM
zebra4's Avatar
Starter kicks in but it wont turn over? Do you mean the starter turns and cranks the engine but it wont start? Or it wont turn over at all? Need to know if it is getting power and turning over, or nothing is happening at all.
Old Dec 31, 2013 | 02:50 PM
No power to starter when key is turned. Touched the starter positive with my positive off my battery charger and it spin like a champ.
Old Dec 31, 2013 | 02:52 PM
It started with not a single problem before I took intake off today. Put it back togeather and now nothing
Old Jan 5, 2014 | 07:41 PM
RocketSkates14's Avatar
so when you turn the key it does nothing ?
Old Jan 5, 2014 | 09:43 PM
joseph143's Avatar
try looking in the fuse box... there are a few fuses that have an engine symbol... check those to start...
there should be two cables to the starter... a large one and a small one.... follow the small one up the harness and make sure all the connectors a tight if you come across any...
other then that... idk what to tell you... if you were bold enough to tear it all down for the sensor you should have enough wit about you to figure a minor issue like a no start out.
Old Jan 6, 2014 | 07:07 AM
Originally Posted by cfdfireman1
Hey MurderedOut09,
Why don't you start 3 or 4 more posts about this same problem? Get a volt ohm meter and learn how to use it. Nobody on Evom is a clairvoyant.
No need to be and a**hole i started other post about it cause nobody was saying anything on the other post and I was trying to get this fixed so go be a dick somewhere else.. K Thanks
Old Jan 6, 2014 | 07:09 AM
Correct. Think its the netural safety switch checking it this afternoon
Old Jan 11, 2014 | 08:47 AM
cfdfireman1's Avatar
How's it goin for you champ?
kindaloweredlif
Lancer Troubleshooting
May 9, 2017 07:14 PM
Wmu240
Dec 18, 2015 10:18 AM
Wmu240
Sep 8, 2015 06:21 PM
06LancerRA
Jan 7, 2015 10:52 PM
usmcrfu
Dec 6, 2012 06:01 PM
