GTX3576 Stock Location ordered
Old Mar 20, 2014 | 02:20 AM
Johnr352's Avatar
Originally Posted by Anexos
I put down 373/320 on a Mustang with a GTX3071 0.94 A/R on stock clutch packs with no slipping. That's about 415whp on a DynoJet. I don't know your mileage or how abused your SST is but you should not need clutches at 350wtrq (DynoJet). Talk with your tuner or find a new tuner with SST experience.
I suggest, btw, the gap between a Mustang and Dynojet is not that large. NASA rules allow for a 10% adjustment and even that, presuming the dyno is set up properly, is likely a little high.
Old Mar 28, 2014 | 06:04 PM
palmerblock's Avatar
I have this turbo, spools up faster than the gtx3071 yes... haven't maxed it out yet... thinking about selling it, as I need 700 hp in the next few months.... so its going to be stoker, big bore, or bigger turbo, or a combo of some sort... im willing to give this one a fair chance before I ditch it...
this turbo at ~22 psi should get you at least 170 more hp than a completely stock x, peak for peak on pump gas
Old Mar 28, 2014 | 08:32 PM
IRPerformance's Avatar
I am putting together a similar setup but went with the 3582. I want at least 500whp on the stock motor. Going to have the following:
ATP GTX3582
ETS 1.9" tubular manifold
Kelford 214C cams and springs
HKS head gasket
ARP head studs
FIC 1200cc injectors
DW 265 pump with wiring upgrade
ETS 4" fmic
Jacks built SST with 600 hp clutch packs
intake, full exhaust, etc.
FYI these turbos are not stock frame. They are stock replacement, meaning they have a custom cast hot side that will bolt to either the stock or any stock replacement manifold.
Old Apr 6, 2014 | 04:56 PM
jpsEVO's Avatar
I'm actually in the market for a turbo right now.... did you sell your gtx3576r? pm me
Old Aug 3, 2014 | 05:51 AM
nalani69's Avatar
which turbo do you have that spools faster than the gtx3071? the 3576?
armaytis
Feb 21, 2017 06:15 AM
pd9000
Dec 15, 2016 09:53 AM
Smolik1010
Jun 7, 2016 08:54 AM
Leeryanl
May 2, 2016 07:12 AM
infinite3k
Jan 17, 2011 07:21 AM
