Autolite XP5701 Sparkplugs.
Old Jul 24, 2014 | 10:25 AM
ikt's Avatar
ikt
Originally Posted by hispanicpanic
My NGK's became a bit fouled up after 20k. They still worked but combustion wasn't even and perfect. Must be why my tuner reccomends you swap them at 20k, which kinda sucks cause iridium is supposed to last like 70k..
Is there a good way to clean these plugs to make htem new again? Or are we stuck replacing them?
you really wanna roll the dice to save $50 bucks?
this is why used Evo's are so scary
Old Jul 24, 2014 | 10:48 AM
IRPerformance's Avatar
20k is actually pretty good on a modified turbo car.
Old Jan 9, 2015 | 08:51 AM
cjsabaki's Avatar
So far about 18,000 miles on these plugs, regapped them to .022 before installing, and zero issues... Less detonation - ping and no fouling issues yet.
Worth a look into....Would like to see a comparison vrs NGK stockers on a dyno. The Autolites do seem to be at least 1 step colder than stock.
Chris
Old Aug 30, 2015 | 03:55 PM
cjsabaki's Avatar
25,000 miles and zero issues. Gapped them at .022, they come outta the box gapped around .045, since they also fit some NA applications.
2009 Ralliart, 93 tune 25 psi max boost, full bolt ons.
Old Aug 30, 2015 | 03:59 PM
cjsabaki's Avatar
Red color is from a fuel additive that contained MMT, from my testing I will say these are about 1.5 heat ranges colder than stock Evo X heat range. The autlite master interchange book and tech department list these plugs as 2 heat ranges colder than stock.
Attached Thumbnails Autolite XP5701 Sparkplugs.-20150830_174624.jpg   Autolite XP5701 Sparkplugs.-20150830_174608.jpg
Old Aug 30, 2015 | 04:06 PM
cjsabaki's Avatar
Better shot of the insulators.
Attached Thumbnails Autolite XP5701 Sparkplugs.-20150830_180339.jpg   Autolite XP5701 Sparkplugs.-20150830_180346.jpg
Old Aug 31, 2015 | 05:30 AM
hispanicpanic's Avatar
Looks like oil in your cylinders??
It seems a set of spark plugs are only good for 2-3 trackdays before they become fouled up. I've soaked mine in seafoam and that seems to extend their life another trackday or two. I don't know why but they get all fouled up and i can tell at idle and low throttle putting around its not very smooth.
I'm considering these autolites as i'm positive they'd foul up in the same time frame but are much cheaper to replace.....
Old Aug 31, 2015 | 07:02 AM
cjsabaki's Avatar
86,000 miles on her, time for a ton of work... Timing chain, cams, n more!!
johnjonfenomeno
178
Jan 7, 2026 09:18 PM
krisdlm
21
Mar 29, 2018 07:26 AM
mRVRsport
Outlander Sport
67
May 5, 2017 04:56 AM
BTR
Oct 18, 2016 08:43 PM
Evoguy!123
Jul 20, 2016 07:26 AM
