Waste Gate Servo Error
Old Sep 19, 2014 | 09:12 AM
Ktmshorty's Avatar
We used EVO scan to try to diagnose a problem and need some assistance. The problem is that the car is only holding boost to about 13 PSI (stock turbo and bolt on mods). We tried adjusting the waste gate actuator arm but there was no difference. We are running an aftermarket boost controller (Blitz). The error indicates that solenoid B is bad. Does anyone know if the aftermarket boost controller would use a stock solenoid or would it need to be replaced with the aftermarket boost controller manufacturer's solenoid?
Also, we might be barking up the wrong tree. We did make a mode that might have created the issue. We changed to an aftermarket blow off valve and changed the configuration to 50% recirculating and 50% to air. It ran fine for a month then started going into limp mode with limited boost. We then changed the configuration of the BOV to to 100% recirculating but there was no improvement. I'm thinking about putting the stock BOV back in to see if that changes things.
Any opinions as to whether it is a waste gate or BOV issue?
Thanks.
Old Sep 19, 2014 | 09:38 AM
Ktmshorty's Avatar
Sorry My Thread title is a little misleading, I meant Solenoid not Servo. Can't figure out how to change it.
Old Sep 19, 2014 | 09:51 AM
sgtr275's Avatar
Have you performed a boost leak check?
Old Sep 20, 2014 | 09:00 AM
Ktmshorty's Avatar
We checked all of the hose connections and tightened them up. Would a boost leak still trigger the solenoid error code? What else can we do to check for a boost leak?
Old Sep 22, 2014 | 09:50 AM
acidtonic's Avatar
The aftermarket kits tend to use their own boost control solenoid and controller.
Old Sep 22, 2014 | 01:58 PM
Ktmshorty's Avatar
So, does anyone know if a boost leak would trigger a bad solenoid code or is it most likely a bad solenoid?
araz5260
Apr 9, 2015 01:31 PM
TMack
Oct 18, 2014 05:31 PM
Vivid Racing
12
Jul 30, 2014 03:40 PM
EvoDan2004
28
Oct 25, 2013 07:58 PM
giangi
Mar 21, 2006 01:15 PM
