Clutch not disengaging. Built transmission
Old Nov 24, 2014 | 09:17 AM
FoxFister's Avatar
I recently had TRE build a transmission for my 10` GSR. When the transmission was taken out, the clutch worked fine. The clutch(exedy twin) was not taken out and the hydraulic line was left attached to the slave cylinder.
When we installed the transmission and started the car, it would jerk forward(if started in gear), and not go into gear(if started in neutral). The wedge collar is still attached. The shop it is sitting at currently thinks it might have been a mix up on TRE's part and they installed the wrong clutch fork(evo 8/9 fork in the X tranny).
Any insight on this? Could an 8 fork be installed into an X transmission and cause this problem?
Old Nov 24, 2014 | 03:13 PM
FoxFister's Avatar
94 views and no one has any advice on what the problem could be?
Old Dec 11, 2014 | 06:28 PM
needbigergarage's Avatar
have you tried bleeding the system?
Old Dec 11, 2014 | 10:41 PM
franzcars's Avatar
what Master cylinder do you have? MIght have given out and needs the newtsb one
Old Dec 12, 2014 | 07:35 PM
FoxFister's Avatar
Happened to magically fix itself. As they were pushing the car onto the lift, it started right up fine Not really sure how this could happen, but oh well.
Everything's smooth now. The transmission shifts better than ever! to TRE
Old Dec 14, 2014 | 11:26 AM
IRPerformance's Avatar
Sounds like the disk seized to the pressure plate. I've had that happen with customers that slipped the clutch excessively, then parked the car. Sometimes it will pop loose. I had one come free once while winching the car onto a trailer.
PKEVO8
Aug 28, 2010 06:17 AM
Boost3dxEvO
Aug 25, 2009 07:15 PM
Boost3dxEvO
Automotosports - Illinois
Aug 17, 2009 02:51 PM
MasterAK
Lancer Troubleshooting
Feb 10, 2008 11:32 AM
petersa9
26
Feb 19, 2005 08:56 AM
