S-AWC mode options no longer changeable
Subscribe
Feb 18, 2015 | 02:13 PM
So i just got a new pump installed last week via warranty and I am already having problems. Normally when you start the car you can select Tarmac/Gravel/Snow before you move, then while the pump is warming up or building pressure for maybe 1-2 minutes if you try and change the mode it will flash at you. Eventually once everything is going you can change it when ever you want.
Now i can adjust the T/G/S mode before i move. Once the car has moved the T/G/S logo is gone and operating the switch does nothing. No CEL, No codes.
Reply 0
Feb 19, 2015 | 10:40 AM
Today i now get the "Service Required" for the drivetrain warning. Still won't pull any codes. I am scanning with EvoScan 2.8 using "EVOX EFI"
Reply 0
Feb 20, 2015 | 12:37 PM
If you're having problems under warranty, best bet would be to take it back to the dealership and have them fix the problem.
Reply 0
Feb 23, 2015 | 01:12 PM
Bahahhaah pump is bad. New one is on order. This must be some kind of record - 1 week failure.
Reply 0
Subscribe
