Timing Chain warning light?
Old Apr 18, 2015 | 06:59 PM
Mikami's Avatar
So I have this warning light on my dash its a yellow triangle with a black exclamation mark. When I looked it up it says timing chain needs to be checked but I also saw it could mean there's a issue in the background?
I also have a Tpms tire light I always dismiss because I removed my tpms sensors when I got aftermarket rims.
So is this the tpms light I dismissed and it shows this to let me know it's in the background or is it actually the timing chain stretching? picture attached
2013 evo x 55k miles. Modded with full bolt ons and tune
Old Apr 18, 2015 | 09:00 PM
ghozt's Avatar
Do you have a way to pull trouble codes? I want to say the exclamation is to warn you of the tpms light, but I've not had mine go off in a while so I'm not positive. But pulling codes should tell you if your chain stretched.
Old Apr 18, 2015 | 09:44 PM
hoobastnk90's Avatar
I have a 2011 and when I switch to my track wheels with no tpms sensors I get the triangle as well even after I dismiss it. I would imagine if it was the timeing chain it would show a warning pop up. Then eventually it would get dismissed and put to the triangle but it would most likely cycle through it first. Your still under the powertrain warranty you could always take it in if your worried.
Old Apr 19, 2015 | 07:58 AM
Mikami's Avatar
Yeah I have an access port and there are no codes. None at all. Does the dealership check stretch level for free under warranty or does the warranty only cover it if it ends up being stretched and needed replacement. I guess I'll call Monday and set a appt to get it checked to be sure.
Old Apr 20, 2015 | 02:26 PM
Jubey97's Avatar
i believe the 2013 evo x has the new revised "beefier" timing chain.
Old Apr 20, 2015 | 02:44 PM
No_Skillz's Avatar
This is the TPMS light. The yellow triangle will appear also. If you tried to pull codes and found nothing, fix your tire pressure, or TPM Sensor, and it will go away.
Berndog67
Aug 3, 2017 04:25 PM
Fawkz
Nov 21, 2014 10:26 PM
josephcastelar
17
Mar 31, 2013 07:22 AM
dukeds
10
Aug 31, 2012 05:18 AM
acidtonic
Jun 20, 2009 07:21 AM
