2015 mid pipe install problem
Old Jun 27, 2015 | 08:02 PM
commbubba19's Avatar
Bought a mid pipe and went to install. No hardware included. I then realized after taking off the factory mid pipe that the studs were welded onto the factory pipe. Is this how it is on the pre 2015? With no hardware I reinstalled the factory mid pipe until I decide what to do. Just sucks as I was hoping to be running this by now.
I was told the factory hardware could be reused but not seeing how that is possible when the studs are welded to the factory flange.
Old Jun 29, 2015 | 09:38 AM
hoobastnk90's Avatar
Are you talking about a test pipe?
Old Jun 29, 2015 | 10:38 AM
splattj's Avatar
You just need to buy some bolts/nuts that fit in the holes of your test pipe. The better pipes come with hardware. I'd recommend a couple lock washers if you can't find (non-nylon) locking nuts.
Old Jun 29, 2015 | 01:45 PM
Yes
Old Jun 29, 2015 | 01:51 PM
Yea you just need to do like the guy listed above said just buy 4 bolts and nuts and you will also need to two 3 inch two bolt gaskets.
Old Jun 30, 2015 | 10:06 AM
I have the gaskets. Just disappointed the hardware wasn't included. Get what you pay for i guess.
Old Jun 30, 2015 | 01:12 PM
Just goto home depot or lowes and by the right grade of bolts and nuts like maybe 5 buxs worth of parts and ur good to go!
Junior Garcia
Lancer Engine Tech
Mar 10, 2018 02:32 PM
IC_White
Mid-Atlantic Region
Apr 5, 2015 06:33 AM
steven88
Feb 24, 2010 12:43 PM
4g63evoeight
Feb 17, 2010 06:18 AM
Messidona
Aug 27, 2008 05:16 PM
